Is it safe to jack the car on the "rubber seat" directly below the springs? Would it be able to support the car's weight?
Photo is taken from the rear underchassis of a Mazda 3 which is more or less the same with the Focus. ![]() |
Old enough to know better
I've always found this link useful.
http://www.focushacks.com/index.php?modid=74 I wouldn't use that particular point to support the car.
Badly Focused
It'll support the weight, for sure, but DO NOT go under the car, or even close, because it'll be extremely unstable. If you're using a screw jack, use the factory jacking points, if you're using a hydraulic jack, I'd try the plate between the two suspention arms, and put jack stands where the factory jacking points are...if you're going to be under the car, make sure you've got jack stands...plenty of people have lost arms or worse from failed jacks...it's only an Oring holding 1000kg from coming straight down...
RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels 16.045...0.05 of a second! I wanted a 15sec pass! 93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE! *Maybe we don't try putting holes in things that sink, yeah?* |
#4 | |||
yum
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
Badly Focused
Block of wood is your friend
![]() RM.
That link is spot on! Thanks!
