Blue Power Racing Developments The home of Blue Power. Website Link |
Hello all
I just got my bluepower CAI today for my BF XR8 Iv removed my stock airbox and just looking at how it all goes together inc reading the instructions. 2 questions 1) Just in front if the headlight there is an earth cable bolted down - next to that is a cable that runs from left to right across the engine bay - when i put the lower half of the intake in - it is pressing against this cable and does not look like any better way to run the cable 2) in the box there was a piece of rubber that looks like it is meant to protect the edge of something, where on the airbox does this go? thanks Luke
2015 Toyota Landcruiser 79 V8 SC |
#2 | |||
BOSS Pilot
The bit of protector sounds like the bit that goes around the inside of the hole in the box where the air filter pokes through?
Could probably go down stairs and have a look to answer the first question if no one else can help
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
Ah that sounds like it - one problem solved
Well i just ended up unplugging it and moving it so it could run unpinched
Appears it is the ABS sensor
#5 | |||
HO INTERCEPTOR
Cheers Glenn
Lightning Strike, BF, 6 Speed Manual, XR8 Ute. Stuff to make it GO by BluePower Racing Developments ....Speed is a byproduct! Body and Visual by HO My Business GutterGuardGuyAluminium Guttermesh Supply & Installation. OrsmFordCruisers R.I.P Wayne Draper
i ended up running it though the corner of the airbox, there was a notch about half way across the airbox but no way was it going to reach that far.
