17-09-2008, 09:16 AM | #1 | ||
'06 Ford Territory Turbo
Hi all. Just bought a '98 model AU and it has the stock radio still in there. We are able to wire the CD Player up to the car without a problem, but are wondering if and how it were possible to connect the steering wheel volume and track controls up to the CD Player.
Any ideas? All help is appreciated. |
17-09-2008, 03:05 PM | #2 | ||
Nange Road Warrior
Mate, it can't be done without purchasing some aftermarket gear...I think it's called The CAT or something like that...give it a google or see a car audio store...
Maybe if a moderator moved this thread to AU Falcon area it would get more attention...
T2 TE50 #082 in Galaxy Blue • ESS Auto • Twin 2.5" Stainless Steel Exhaust by Manta • Premium Brakes • 18" Azzuros • Premium Sound • K&N Filter • 1985 XF Falcon GL • 4.1 • 4 Speed Manual • 15" Steelies • Snow White • Otherwise stock...for now • 2004 Porsche Cayenne S • 4.5 V8 • 6 Speed Auto • 19" OEM Alloys in Bronze • Crystal Silver • Sunroof • PASM • The grocery getter •
17-09-2008, 03:19 PM | #3 | ||
Afterburner + skids =
No no need to move it nutter, the information you gave is 100% correct.
The piece of equipment you need is a CAT09. Quite pricy though. http://www.thecat.net.au/Images/THE%...0Brochure2.PDF EDIT- Seeing is it is in the pub, maybe it should be moved.
19-09-2008, 05:57 PM | #4 | ||
Thanks for clearing that one up guys.
Here is another one for you; Will the AU 2 CD Player connect straight up to the AU 1 plugs and work straight away albeit not have the extra controls on the AU 1 steering wheel? Thanks. |
29-07-2009, 10:09 PM | #5 | ||
A bit late I know but yes, the AU II/III one will fit into the AU1 fascia ( a little cutting required) and the connectors plug straight in and work but, no remote volume :(
30-07-2009, 08:54 AM | #6 | ||
The Monty
i can wire a cd play no dramas but not to sure on other stuff haha, when i got my dvd player isntalled i was going to get a CAT done too but there going to slug me an extra like $200, so i said stick it :S wish i did tho would come in handy just the price seemed a little out there.
it works via I.R yeah? how do you do it? cheersZ brad` |
30-07-2009, 01:03 PM | #7 | ||
Resident AFF detailer
31-07-2009, 11:50 PM | #8 | ||
ROCKING THE EL FUTURA
woohoo i know what im instaling on the weekend......
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
27-01-2011, 10:06 AM | #9 | ||
is it hard to install?
27-01-2011, 07:24 PM | #10 | ||
Hi. Depends on what you call easy, the new radio/cd must be remote capable ( I R or cable on back ) and when your putting in the head unit the cat 10 just hooks up with acc and earth for its power the wire that goes to the steering wheel for a signal and either a hard wire to rear of head unit or if infra red you run a wire up the pillar and out through the interior light hole and just have a infra red led poking out between the lamp and the headlining. Comes with full instructions and switch programing which is so easy compared to some that you need to push buttons and step to next function etc etc etc damm start again. Cheers MD
27-01-2011, 10:20 PM | #11 | ||
There is a cheaper option, a bit more fiddly to program though:
http://www.pac-audio.com/SWI/ Can be had for $60 delivered from ebay USA See http://222.fordforums.com.au/showthread.php?t=11295688 |
