I ended up saving this 2000 AU1 Ford Falcon from going to the scrap. It was having a overheating issue, coolant leak and intermittent no start. Turns out the overheating was due to the cooling fans being unplugged. The coolant leak form a loose radiator drain bung and the intermittent start has something to do with the automatic gear selector, if you slide it through the gears and give it a little shove into P it starts right up
![]() I'm thinking of selling it, It is in reasonable condition with 260k on the clock...still runs nice and smooth. It does have hail damage here and there as well as the clear peeling at the rear on the quarter, bumper and bootlid. Other than that I don't see why it wouldn't pass a roadworthy inspection. The tyres are at ~80% and it has a new radiator (might have been why the bung to drain it was leaking?) Would asking $1500 be too much? Selling it unregistered and without a RWC Some pics... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Boss powaaaa |
Defender of the faith
Keep it as a daily imo
Nice looking ride. Cleaned up well. Nice colour. Good for you to do get it working with basic repairs - just goes to show 'big' problems for some aint so big for others.
I have/have had same problem with mine starting. Happened after an auto recon. Dint bother about it. Happens more in winter than summer. I can shuffle gear stick about and that helps, or move to neutral for start. Easiest for me is just to push the stick firmly forward when in park. Doesn't happen much now. Seems too cheap, check out used car market. You could get a few hundred more.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension -- ----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 ----- -------- Preventative Maintenance Policy -------- |
Flairs - Truckers Delight
Ah, regency red, arguably the best AU colour.
The part which prevents starting in a gear other than N or P is the inhibitor switch. They are white, cheap, and external on the passenger's side of the automatic transmission. Just a couple of screws and a plug from memory.
#5 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
If you selling it put it in the for sale section If your on a fishing trip try ebay no reg, no rwc, hail damage, 260klm.. on 13 year old falcons are worth little or what ever you can get,
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
