Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link |
#31 | ||
2011 FG mkII GT Kinetic Auto 12.61@113mph and 12.65@116mph |
5 users like this post: |
#32 | ||
4 users like this post: |
#33 | ||
Regular member
Definitely shows off the brakes alot better.
Verdict on how they're performing so far?
CURRENT 2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance. OLD 2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw |
#34 | ||
I really can't fault them at all. Very factory feel, no noise. Some quick street, back road driving so far. Very happy, I can't stop staring at them they look awesome. The tire fitters were very impressed.
#36 | ||
Brett- any chance of seeing the front calipers in red with shockworks logo in black.
I just like the red calipers to stick original FGX XR8 look, and the red looks nice against my smoke colour. Seen many other calipers that are red and not brembo, and if you have shockworks logo in black- should not be an issue? Anyway, is there room for red calipers with black shockworks logo on it? Cheers
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
#37 | ||
For those interested, it was my car that cracked the first set of Shockworks rotors but this is under extreme conditions with 285 slicks on the front with an overworked 4 pot Brembo that created hot spots due to lack of pad surface area.
The service from Brett at Shockworks was exceptional though and the rotors were replaced. I have not had a problem with the latest set of Shockworks rotors and that includes a few more full track days on 285 Hoosier R7's. From a design point of view this 6 piston caliper with the 34mm directional vanes has me very interested. 34mm provides the heat sink ability I require and I am very interested in these 6 piston Calipers.
FG XR6T ZF 350,000kms+ Road registered Lap record holder at Wakefield for any Ford or 2wd 4 door, of any make.....ever!! Wakefield 1.07.4 SMP GP 1.48.1 Marulan 43.4 Winton 1.35.4 |
#38 | |||
We are making a new order now so will have a few sets in red, in the near future:-) Cheers Brett Last edited by Shockworks; 25-05-2017 at 01:49 PM. Reason: Mistake |
#39 | |||
![]() PM sent
#40 | ||
Could we get some measurements available to check wheel clearances for this package?
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits |
#41 | ||
I was given a template cut out, and can say that the calipers do fit in the FGX XR8 standard front rim. But it is tighter than the Brembo 4 pots.
#42 | ||
I just gave that template a go on Enkei RPF1 18x8.5 +30 and it wouldn't clear by the smallest amount. I am going to take the template and try them on a set of 18x9.5 +15 RPF1's as the groove may be positioned differently in the wheel where it fouls possibly allowing clearance of these brakes. Those will likely be my new front rims, fingers crossed it will clear.
#43 | ||
Can the next lot of photos posted not be done through Photobucket please? I can't see the damn brakes you are all talking about!!
Incoming Ride 2022 Everest Sport Blue, V6 with Touring Pack. Current Rides 2014 FGX XR8 - Kinetic, auto. Mods: Manta Twin 3" S/S Cat Back - Loud Version, DPE High Flow Cats, KPM Streetfighter Stage 2 Intercooler, KPM Twin Air Filter, Herrod High Flow Fuel Pump, JLT/Herrod Oil Catch Can. Tuned by Monsta Torque to 403rwkw. 2013 Ranger XL - White. Previous Rides 2005 BA MK 2 XR8 - Winter White, auto, custom twin 2 1/2" s/s exhaust, pacemaker extractors. |
#44 | ||
Just had a delivery to my office.
All work suspended for last hour while I opened up the shockworks kit boxes-feeling like a kid at Christmas again. Seriously impressive gear- I do not know which is more impressive -the rotors with beautifully crafted cooling vane 34 mm thick discs with such nice centre alloy hats...or the massive 6 piston calipers. These calipers have massive pads- 190 mm in length, compared to the Brembo 6 piston Brembos in FPV that use pads 164.8 mm in length. A thought kept moving through my mind that I have sorta gone over the top- but I did suffer bad brake fade with the Brembo 4 pistons and at 45,000 km the OEM rotors are lipped badly and are almost throw away. Serious engineering right here-congrats Brett on your kit- cannot wait now to get it all installed.
7 users like this post: |
#45 | ||
Given not many photos- attached photos showing rotor with alloy hat, and side view showing 34mm thickness- and incredible vaned cooling fins which pumps air from centre outwards to cool.
#46 | ||
Can you post pictures your calipers please, the previous pics dont seem to show up. What's the cost for the 6 piston caliper and rotor upgrade?
Thanks.
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock |
#47 | |||
I only have 2 basic shots when I took the calipers to my local paint/panel shop for repainting- I want the calipers a deep ruby red as they are so big I want them to be more subtle. Here are shots when we were breaking them down. Also a comparison shot of the pads, one is for Brembo 4 piston calipers that comes standard on FGX XR8. The other is the pad from the shockworks 6 piston caliper- anyone guess which is which? Cost was $2,500 for full kit with mounting brackets.
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender Last edited by asagaai; 06-08-2017 at 06:42 PM. |
#48 | ||
My question was for the Shockworks guys but thanks for posting the pictures and your feedback. $2,500 seems well priced if it includes the rotors, calipers and pads.
What is the rear 4 piston caliper and rotor upgrade worth and are there any pics? Thanks.
#49 | |||
I messaged Brett last week. Said ill be waiting 7 weeks for the 4 piston set up, which in my opinion is a better option than brembo 4 piston options which are 2 piece, and around the same $$ for a secondhand set. Includes discs and pads.
#50 | |||
GTF Smoke with Black stripes. |
#51 | ||
Regular member
Pretty sure they'd be almost the same, Brett said in his earlier post on page 1 of this thread that he designed the Shockworks calipers so they would take Brembo pads for replacement ease.
#52 | |||
The pads used in the shockworks 6 piston is 190 mm in length, same pad as used by the Bremo Brembo 6 piston caliper used in the Brembo Grand Turismo series, so a much bigger caliper than the 6 piston caliper Brembo used in the FPV and Sprint Brembo 6 pistons. The Brembo Grand Turismo of that size is used in the Grand Cherokee Trackhawk. So they are not teh same as the Brembo 6 pistons used in FPV/Sprints, but are the same as the monster Brembos used in the Trackhawk.
#53 | ||
BOSS 5.4L Enthusiast
Can anyone confirm if these will fit inside an 18" BA XR8 or BA GT wheel?
I believe I can fit 6pot Brembos but these look like better value for money and if their coil overs are anything to go by the product will be second to none. |
#54 | ||
You need to get a template from Brett.
#55 | |||
3 users like this post: |
#56 | |||
#57 | ||
Attached is our template for the 6 pot brake upgrade. Cut it out 1;1 scale and place in the rim to check the clearance.
Cheers Brett |
#58 | ||
Got my calipers back from painting- more ruby than appears in photos. Look fantastic- will be going clean based on consensus-no stickers-calipers so huge and beaut ruby is enough.....
9 users like this post: |
#59 | ||
My rear calipers and rotors arrived today. Hoping to get them fitted early next week. I'll try and get some photos up too.
#60 | ||
Can someone confirm the pad thickness on the fronts? Thanks.
