Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
#151 | ||
Race Brakes Sydney
It is only the paint mate we just get better pricing to move the black ones
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
#152 | ||
Hey Matt,
Is there an upgrade Brembo caliper for a rear single piston PBR caliper over the 328mm rotor? (for a sedan). Is it a complete bolt on setup? If so, how much for a black set with braided lines. Cheers, Dom |
#153 | |||
Race Brakes Sydney
A complete Black brembo rear kit with DBA T3 correct rotors and genuine brackets,pads and rubber lines will cost about $2350.
MATTHEW PEARCE
#154 | ||
Hi Matt.
Hope you had a pleasant brake ; / . I have 2 sets of front Brembo rotors so I'll be ok there for a while. I may be looking at upgrading from my 4/1 caliper set up in my FGF6. I understand that I would need new rear discs. Can you please supply a quote for a 6/4 caliper set up with braided lines with 2 rear discs ? It's just something for me to ponder & later when I get funds I will check on suitable pads. Track/road. Cheers |
#155 | |||
Incoming Ride 2022 Everest Sport Blue, V6 with Touring Pack. Current Rides 2014 FGX XR8 - Kinetic, auto. Mods: Manta Twin 3" S/S Cat Back - Loud Version, DPE High Flow Cats, KPM Streetfighter Stage 2 Intercooler, KPM Twin Air Filter, Herrod High Flow Fuel Pump, JLT/Herrod Oil Catch Can. Tuned by Monsta Torque to 403rwkw. 2013 Ranger XL - White. Previous Rides 2005 BA MK 2 XR8 - Winter White, auto, custom twin 2 1/2" s/s exhaust, pacemaker extractors. |
#156 | ||||
Race Brakes Sydney
These Brembo parts are getting harder and harder to get and new BA BF 6 piston calipers are not available new at the moment but we can still get some FG ones for now and for a complete FG 6/4 kit less front rotors the price would be about $5700. with rubber lines and $5950 with braided lines. Black may be a little cheaper if that was an option.
MATTHEW PEARCE
#157 | ||
Looking at purchasing 4 pod brembos for fg xr6 turbo. What price am i looking. Is anyone selling?
#158 | ||
Are the rear f6 fg brakes the same as the territory rear brakes? Also what roters messurments do i need for the rears for these brakes to fit fg series 1 xr6t.
#159 | ||||
Race Brakes Sydney
New 4 pot kits for front are from $2350 upwards.
MATTHEW PEARCE
#160 | ||
Sorry Mathew. Thanks for reply ill save some more dough for a set of fronts in the future.
#161 | ||
Race Brakes Sydney
No problem at all just didnt want the thread turning into a used parts thread as well.
MATTHEW PEARCE
#162 | ||
Hi, I’m chasing info regarding fitting 4 pots to the wife SY II terry. I have the brembo a, need dogbones. Apologies if wrong place.
#163 | ||
Race Brakes Sydney
Did we talk on the phone today ?
MATTHEW PEARCE
#165 | ||
I foolishly started a thread in the Brakes section, not realising we already had this resource. Great to have such expert advice available.
I need to replace the brakes on my 2009 Territory Turbo Ghia, and I'm thinking up upgrading to either 14" or 15", as per the FPV GTs and/or Mustangs. So I have a series of questions:
#166 | |||
Race Brakes Sydney
So I have a series of questions:[LIST=1][*]Will the bigger Rotors and Calipers fit under my Factory Turbo Ghia rims. (18", standard 7.5" 36.5mm offset.) I know that 14" rotors will fit 18" rims, but I don't know if 15" rotors will fit, nor what offset is needed for the Brembo Calipers. - No and if you go larger than 14" rotors custom brackets will need to be made and clearance depends on the wheels you get [*]Will the Brembo Calipers bolt straight on? - No Or do I need dogbones? And if so what are they made from? You will need brackets and they will be either steel or alloy I have seen some awfully flimsy crap sold as "Brembo Fitting Kits" and I certainly wouldn't trust my brakes to them. - I wouldn't either [*]Do I need to change the Master Cylinder, ABS Module, EBD pump, etc? We haven't had too [*]Is any reprogramming of the TC or DCS required? Not that we have seen customers need to do [*]What is the advantage of cross-drilled, slotted, and/or dimpled rotors? Looks but mainly dissipate heat and water and cooling along with grip..
MATTHEW PEARCE
