Old 07-07-2023, 03:23 PM   #781
efgiar
rofl copter
efgiar's Avatar
Default Re: FORD technical service bulletin : ICC touch screen display
Hi all, im trying to find a solution to repair these ICC screen, just after jasonacts program if its still around to try get over the next hurdle im in.
GQ patrol.
thats all
Old 07-07-2023, 04:31 PM   #782
jakka351
jakka351's Avatar
Originally Posted by Bonswally View Post
Mate is that software you're using available to a novice like me? I'm really keen to be able to switch a fg mk1 fdim from dual zone to single zone.
I was hoping it was going to be something I could do in forscan but that doesn't seem to be the case.
Yes, it is definetly available to anyone including DIYers. facebook.com/testerPresent
jakka351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2023, 04:33 PM   #783
jakka351
jakka351's Avatar
Exclamation Re: FORD technical service bulletin : ICC touch screen display
https://github.com/jakka351/FG2ICCComms
Heres a Visual Studio Solution of JasonACTS program. I am unsure why the repo was deleted. and I have put this up without his permission, if he asks me I will have to take it down.
Old 16-07-2023, 06:17 PM   #784
jakka351
jakka351's Avatar
Removed as per JasonACT request.
Old 16-07-2023, 11:06 PM   #785
steve101
steve101's Avatar
dame just missed it, really wanted to have a go at upgrading my maps, oh well back to using the phone
2014 Fg Mk2 XR6 Turbo
2005 Ba Mk2 XR6 Ute
steve101 is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2023, 05:36 PM   #786
jakka351
jakka351's Avatar
Talking Re: FORD technical service bulletin : ICC touch screen display
Sorry have to respect his wishes. He might not be able to beat me in a car race, but im pretty darn sure he could probably hack my **** if he really wanted to.
Old 20-07-2023, 06:17 PM   #787
steve101
steve101's Avatar
All good, its actually good to see people respecting other peoples hard work and wishes
2005 Ba Mk2 XR6 Ute
Old 20-07-2023, 06:25 PM   #788
jakka351
jakka351's Avatar
I have started hearing of people swapping the Mk1 colour screen into Mk2s.
Old 20-07-2023, 09:16 PM   #789
JasonACT
Away on leave
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Outstanding work on the FG ICC issues. Technical Contributor: For members who share their technical expertise. - Issue reason: The insane amount of work he has put into the Falcon FG ICC is unbelievable. He has shared everything he has done and made a great deal of it available to us all. He has definitely helped a great deal of us with no personal gains to himself.
M8, you can do whatever you want with it all, but don't put words in my mouth.
That goes for anyone using it commercially, and wanting to restrict distribution.
I made no such request.
JasonACT is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2023, 09:34 PM   #790
jakka351
jakka351's Avatar
You made no such request to remove the software????
Old 20-07-2023, 09:35 PM   #791
jakka351
jakka351's Avatar
Whiteford you turdburgler
Old 20-07-2023, 10:12 PM   #792
efgiar
rofl copter
efgiar's Avatar
Hi again, so been playing with it, and got a bench harness setup, at a sticking point at the moment with the software, any tips? im happy to have full onus on myself for failures of anything relating to the software @JasonACT , btw ive replaced the nand flash on a failed unit, just trying to get firmware from a good one to the one with the replaced nand to confirm its been fixed, this is what im getting trying to read the good unit (has gps)
ATZ
ELM327 v1.5
>ATM0
OK
>ATCF7AE
OK
>ATCM7FF
OK
>ATSH7A6
OK
>ATTPB
OK
>10FA
50 FA
>2701
7F 27 22
Condition not correct
>1081
50 81
GQ patrol.
thats all
Old 20-07-2023, 10:32 PM   #793
jakka351
jakka351's Avatar
"Recall Campaign Proformas"
http://www.fordservicecontent.com/Fo...te_process.pdf
What recall?
Old 20-07-2023, 10:38 PM   #794
jakka351
jakka351's Avatar
ATZ
ELM327 v1.5
>ATM0
OK
>ATCF7AE
OK
>ATCM7FF
OK
>ATSH7A6
OK
>ATTPB
OK
>10FA
50 FA
>2701
7F 27 22
>1081
50 81
is this on the bench? you might find that security access requests will fail unless the FDIM receives the right CAN messages from the rest of the car. at very least I think you just need to send 0x406 byte 2 set to higher than 0x05 (I think). Or you can try it to a module in the car. That message is just ignition on.
edit: here are some scripts that may help https://github.com/jakka351/FG-Falco...esources/Tools
specifically this one called "wake_fdim.sh" https://github.com/jakka351/FG-Falco...s/wake_fdim.sh
JasonACT's arduino sketch with my handy dandy comments for the thick: https://github.com/jakka351/FG-Falco...s/CAN_test.ino
Old 20-07-2023, 11:31 PM   #795
jakka351
jakka351's Avatar
I got bored and added a few things to Jasons program. Available at the link down below.
Old 21-07-2023, 11:24 PM   #796
jakka351
jakka351's Avatar
Arrow Re: FORD technical service bulletin : ICC touch screen display
Originally Posted by Whiteford View Post
Tester Present
testerPresent*
Old 21-07-2023, 11:49 PM   #797
jakka351
jakka351's Avatar
7e 01
no its 3E 01
Old 24-07-2023, 12:19 AM   #798
steve101
steve101's Avatar
does anybody know where i can get the repair.zip from post #694 and the navimaps.zip from #783 as it looks like the repo has been deleted, thanks
2005 Ba Mk2 XR6 Ute
Old 03-11-2023, 08:30 PM   #799
jakka351
jakka351's Avatar
Explanation of how to set the FDIM display to be either Single Zone or Dual Zone.
There is a memory.location accessible via Diagnostic service 0x22 readDataByCommonId in the mark 1 and 2 Colour FDIMs located at 0xE205 that can be set to 0 for No AC, 2 for Single Zone or 3 for Dual Zone. Writing to the memory location can be done via service 0x2E and doesn't require security access.
Old 30-07-2024, 03:46 PM   #800
ntguy
Could this be done in a FGX??? I have converted to Sync3 and AC climate control is for dual zone. I have only have single zone?? So nothing up on the screen at all
ntguy is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2024, 04:18 PM   #801
jakka351
jakka351's Avatar
I am not sure, but I believe we spoke about this last night on facebook lol.
Old 30-07-2024, 04:46 PM   #802
ntguy
We probably did........ I am ordering OBD2 Usb lead....
Somehow it seems the FGX HIM is different?? All FGX have climate control, however some a single zone and others are dual...... I wonder if its same HIM for both. Then some programming on the APIM and also installing the 2nd motors on drivers side???
Being not a lot FGXs around, there is not a lot of interest it seems. Even less FGX one tonner pov spec utes.....
Then to throw in the mix, swapping over to Sync3
Old 11-08-2024, 07:30 PM   #803
jakka351
jakka351's Avatar
Update:
I have created a J2534 implementation of JasonACTs FG2ICCComms program, same thing just uses a J2534 Interface instead of the ELM327.
Available for download from the github https://github.com/jakka351/FG2ICCCommsJ2534
And my program FoA Orion Comms which is a full diagnostic and firmware suite for the FG Falcon, able to Flash the PCM, Read the IPC EEPROM, lalalaladeee da is available for purchase. It is derived from FG2IPComms but has become its own beast.
Old 16-08-2024, 07:28 PM   #804
jakka351
jakka351's Avatar
And just to be a tease...
This is not available to download.
Old Yesterday, 09:01 PM   #805
Boosted_G6
Guys have just had the blank screen of death
Seems I can work all controls but cannot turn the radio on and off
Is it the lcd and back light that's failed or is there more to ithanks in advance
Boosted_G6 is online now   Reply With Quote Multi-Quote with this Post
Old Yesterday, 10:57 PM   #806
Boosted_G6
Thanks Peter, yeah, it's important you have a backup. I'm more interested in someone with an exchanged unit, to take photos of the boards (for a small fee ~ $20) to locate the problem quickly. But if you don't have any luck and give up on the boards, I'm more than happy to pay you something for it.
It would be fairly easy to replace that whole 9v / ?v (dimmed) LED Driver part with a custom mod (9v regulator, Arduino & MOSFET - PWM driven with a new plug for the red/black wires). So one way or another, I reckon it will live again.
I'm going to try to link pins 1 & 5 on the large board today - to see if it'll power up without the small board plugged in.. With them sandwiched, it's hard to take any readings while it's on.
Hey
Could you pretty please pm me
Old Today, 10:54 AM   #807
Boosted_G6
Update:
Do you sell a package so one can reflash a corrupt fdim
Old Today, 03:08 PM   #808
olfella
Cranky old bastard
Mine played up last year but it did not fully die (similar to yours) but put a new battery in and it has been good ever since. So first up I suggest you see if your battery is OK. Cheers
"But really...what can possibly go wrong"
olfella is online now   Reply With Quote Multi-Quote with this Post
Old Today, 03:10 PM   #809
Boosted_G6
No go sigh 4 months old also had it charge over night
