hey guys
recently while just driving sedatly or just for no reason what so ever (even sitting still) the traction control and ABS lights on the dash come on and stay on for a while then turn off again when they feel like it.. what does it mean? im thinkin it MAY be a loose connection but what else could it be? thanks guys |
same problem with mine, low-speed braking applications (especially in carparks) seem to enable my abs light? its really starting to worry me. Also only seems to happen after maybe a hard brake earlier in the day (hard brake but not enabling ABS at that time)
ive only had ABS kick in 3 times since ive had the car
twice on a very slippery wet roundabout(was semi on purpose as i had only just got the car and figured why not(was pre entry with no 1 else around) as id never had an ABS car before and the 3rd time i hit a large divit and the car got all light and i braked as a corner was comming up and it kicked in but yeah i dunno what it is still stops fine |
Posts: n/a
mine did that some time ago. get under the car and clean up the abs sensors.... they're easy enough to locate. you'll find especially on the fronts they build up muck and metal shavings from the discs. they are essentially magnets and need to be relatively clean to be able to mark the rotors off the wheels. that will fix it 80% of the time.
roger that, will get under mine tommorow n have a looksie, sepcially since I took the VCT ST rallying not long ago....
got damn that car luuuurrrrrrrves the peagravel ![]() |
thanks fellas!!
its good to not havta ask some moron at ford to fix it!! |
hmm cleaned off PILES of metal shavings off the front.. havnt done the back YET.. but its still doing it!!
hope it isnt anything serious.. the car stops and goes as well as it always has.. havnt tryed to enable ABS yet to see if it still works with the lights on.. .. or TCS for that matter.. ill clean up the rear ones as soon as i can and see what happens |
Posts: n/a
if cleaning it up doesn't work you may be having some issues with the abs modulator. that can be checked with the ford resting equipment in a cuple of minutes. but don't stress too much, if the loights are on that just means youer traction control and abs aren't functioning. the brakes will still work fine, they'll just lock up if yoiu hit them too hard......... same as a pre-abs equiped unit.
aaa cheers for that francisjones
so whats a ABS modulator worth to replace :S.. stupid techno rubbish |
Three posibilities:
1. The ECU on the ABS unit has an intermittent fault 2. There is a poor wiring connection somwhere in the circuit 3. One of the wheel speed sensors is faulty FF |
matty
is it possible to over ride traction control in a AU III XR6 AUTO?
#12 | ||
should be a traction control button on the dash?
#13 | ||
Formally Kia Chaser
was traction control optional on the I6?
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#14 | ||
mine is a fairlane ghia and is the I6 and has Traction control standard *cry*
id much rather an LSD!! was so much nicer to drive my old ZL fairlane with LSD over the traction control especially when trying to accelerate hard into traffic from a stand still .. slight bit of slip and the traction control kicked in and made for a few close calls.. but the LSD just GOES with a lil bit of *** sideways action
#15 | |||
Formally Kia Chaser
