13-07-2016, 04:16 PM | #1 | ||
I had mechatronic unit/TCM replaced in my Powershift a couple of months ago and the shifts now seem to be at significantly higher RPM than before.
I'm not quite sure how different it is because I only had the car a week before it went off for repair for a month. I swear it was much lower before though, especially 1st to 2nd which is now around 3000 under fairly sedate acceleration, which feels too high to me. I know some transmissions learn and adapt to how the car is driven so I thought the difference I'm noticing may have something to do with this and that it might return to 'normal' after a while. It hasn't. Anything I can or should do to get the transmission to learn after the repair? |
13-07-2016, 04:21 PM | #2 | ||
I take it yours is the petrol model??
Manual shift with it for a while and see if that helps. Mine has not given me any issues (touch wood).
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
13-07-2016, 04:23 PM | #3 | ||
Sorry, should have mentioned. MC Diesel wagon.
13-07-2016, 04:25 PM | #4 | ||
OK, definitely a problem.
Ford did the fix for you? I think time for a return visit!
13-07-2016, 04:35 PM | #5 | |||
Can you elaborate on why it's definitely a problem. Shifting too high? If it's so clearly not right I'm surprised it wasn't picked up by the ford dealer (different one) I got it serviced at after the transmission fix. Maybe they didn't test drive it. Last edited by manchu; 13-07-2016 at 04:36 PM. Reason: spelling |
13-07-2016, 04:57 PM | #6 | ||
Yep, shifting way too high, if you are driving it moderately.
You don't have it hooked over into sport mode, do you?
13-07-2016, 05:05 PM | #7 | ||
13-07-2016, 05:43 PM | #8 | |||
http://www.fordforums.com.au/showthr...1452297&page=2 |
13-07-2016, 05:52 PM | #9 | |||
13-07-2016, 06:45 PM | #10 | ||
Apparently the power shift has adaptive learning,BUT when it is reset by the repairer they take it for a long drive to set the perameters for the shifts.
BUT if the memory is set by the first driver what happens when the owner takes the car and drives differently to the first driver?????? If this in fact is truely correct the car should be driven by the intended driver under instruction by the ford repairer. |
14-07-2016, 09:29 AM | #11 | |||
You haven't just bought a new pair of steel-caps, have you ;-) ?
14-07-2016, 09:34 AM | #12 | |||
edit..no. no new steel caps. Just looked at the acceleration in modaveos plot. about 8 seconds to 50km/h, so reasonably sedate I think. ?? Last edited by manchu; 14-07-2016 at 09:40 AM. |
14-07-2016, 10:05 AM | #13 | ||
Oops! My bad.
I'll have a look at mine tonight, if the missus arrives home a t a reasonable hour.
14-07-2016, 02:44 PM | #14 | ||||
15-07-2016, 09:22 AM | #15 | ||
The gearshift control system uses (non-adaptive) software algorithms which take into account driving conditions and driver input.
The TCM controls and adapts to the mechanics of gear change by monitoring hydraulic pressures, shaft speeds and selector fork positions. Relevant data is stored in non volatile RAM. At least that's what I gather from looking at the text in the manual, just letters and numbers after all. I inferred that the TCM software remains the same (but makes decisions based on variable inputs from the mechanical system). When 'S' is selected the software just switches to another algorithm, using the same data in RAM to control the gearshifts. So no, the TCM does not adapt to the driver, it adapts to the gearbox? Last edited by rondeo; 15-07-2016 at 09:36 AM. Reason: addition |
17-07-2016, 06:55 AM | #16 | ||
After reading this thread, I paid more attention to the shift points on my MC, seems to shift in the lower gears (1->2 & 2->3) around the 2800 RPM mark that Mondaveo has plotted, especially if going around a corner.
After it has warmed up it does seem to shift a little lower, and definitely shifts at lower RPM's in the higher gears
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢 2008 Peugeot 308 HDi - Highway Hack II 2008 Citroen C4 HDi - Highway Hack III 2010 Peugeot 308 HDi SW - Shaggin Wagon II 2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power ! 2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone 2022 Volvo XC40 T4 Inscription - Shopping trolley II 2002 BMW R1150GS |
19-07-2016, 06:29 PM | #17 | ||
I'd be getting it looked at. Mine shifts at close to 3000 in the first couple of gears under some circumstances but mostly it's much lower. For example it will do it when dead cold first thing in the morning and when accelerating up a couple of the hills around my place.
When it is warmed up and especially when I am in the usual heavy traffic it will shift 1->2 and 2->3 at under 2000rpm. Sometimes it is slurring into second befoer teh car has even moved a car length. Though it can vary and sometimes it will hold gears longer under exactly the same circumstances for whatever reason. I think there are many inputs it takes into account when deciding on when to shift. Things like perhaps speed, engine speed, engine temp, gearbox temp, ambient temp, throttle position, torque output, turbo boost etc. Perhaps your new TCM isn't receiving one of these inputs correctly? For example if it thinks the engine is cold all the time it may stay in cold running mode and hold gears for longer?
2016 Kuga Trend TDCi |
20-07-2016, 09:06 AM | #18 | |||
If I shift manually, I do so at around 2k. Sorry for the confusion.
Thread Tools | |
Display Modes | |
