hey all
I have vn calipers and borg warner drums on my mark 1 capri I want to put a larger master cylinder on the car does anyone know of anything that will bolt up easily that has a larger internal bore? cheers Quinton |
Apparently you can use one off a Rover SD1 or even a Range Rover so I have been told. 1" bore & a bolt on fit.
mk 1 capri
apprently one of a centura will bolt up to a 4 cyl booster and run a four wheel disc brake setup.not what you got but a bit of useless info.
source-hoppers stoppers |
Yes, think big british cars of the same era. Land/Range Rover, I know for sure fits. I think you can even use one from a Jag.
