11-10-2008, 06:55 PM | #1 | ||
Smile
Yes I need to mod a little more..hehe. I have been studying msd ignitions but the amount of failures and slow backup service have made me not commit to this system. Are there other systems available?
The Ba's have coil on plug which is an awesome system..What can we do for the au sixes?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
11-10-2008, 08:57 PM | #2 | ||
What are you wanting to upgrade exactely? ICE do some great gear but they are mainly do V8 gear. they might have waht you are looking for
11-10-2008, 09:30 PM | #3 | ||
Smile
Ive talked to ice but they dont cater for wasted spark. I think that the ignition system is a compromise for the perfomance six. Imho the standard au six ignition is a barely workable compromise for profit.
11-10-2008, 10:47 PM | #4 | ||
you could easy run a coil for each plug but youd need a different ecu (ie piggyback) to control them....alot of rotary guys do this they use bosch coils....and if your using a piggy back ecu you can control the fuel as well so your gonna get a gain there as well...the only problem is getting someone with a dyno to tune it.....i used to work at a place that sold microtech and we used to fit them to all sorts of cars hey even on a stock car you will get good gains.....
11-10-2008, 11:45 PM | #5 | ||
Smile
I was thinking of a way to have a similar ignition as msd with the to provide a better spark. Maybe coil per plug and a capacitive multi spark. I dont believe there is a huge amount of power to be had but I suspect a much fatter power /torque curve.
11-10-2008, 11:50 PM | #6 | |||
Smile
12-10-2008, 01:27 AM | #7 | |||
Boost Addict
the AU ECUs have build in igniters, so any dumb ignition coil will be fine, however from personal experience i would use the LS1 coils, which are smart ignition coil (build in igniter), they also take just about any charge rate u throw at them as they have an internal regulator. i havent tried them myself with a stock ecu yet, however from a technical point of view i dont see a reason why it shouldnt work. id just wire the coils into pairs and that should work fine without an aftermarket ecu. i found quite a few second hand units on ebay for quite reasoanble prices (around 100 to 150 mark for a complete set), which i am using on my V8 setup. as for tach adaptor: no the tach signal is generated in the ecu from the cam and crank sensor, so it will continue working even after u change coilpacks. teh stock au coilpacks have 4 wires in: 1 power wire and 3 signal wires, so u just use those for ur coils.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
12-10-2008, 03:20 AM | #8 | ||
you could also try motec http://www.motec.com.au/ignition/cdicoils/
12-10-2008, 10:57 AM | #9 | ||
Boost Addict
the dual post items are the same as the haltech units (or essentially bosch)
12-10-2008, 11:00 AM | #10 | |||
Smile
I know of the ls1 coils but was not sure if my ecu can cope with sinking a trigger above a certain amperage. I suppose we can try. The existing coilpacks fire in pairs so if the current ecu is doing that then I dont see why it cannot fire 2 separate ls1 coils. The only other issue in my mind is that I have read that wasted spark au fires the coil 2 times per cycle.I believe it fires one coil positive and has a negative on the other.The effect is a weaker spark in the non firing cylinder.I am notsure that this is correct as more often than not most people say that the coils fire up a paired coilpack with a positive charge? I am not sure on this yet either.Any more info would be great..
12-10-2008, 12:20 PM | #11 | ||
Smile
I might head down to the local holden wrecker and grab 2 coils to try this out.Hopefully wont burn the ecu..hhehe
12-10-2008, 04:39 PM | #12 | |||
Boost Addict
the triggering of the au coilpacks as well as the LS1 is done through negative signalling, again same principal i have used when i converted a camry from dizzy to waste spark coilpacks LS1 (again wired two coilpacks together and used one signal to fire both)
12-10-2008, 06:18 PM | #13 | |||
Smile
Thanks : So each coil pack pair we have now should run the 2 new corresponding ls1 coils with their 1 negative pulse..correct?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again Last edited by Stav; 12-10-2008 at 06:24 PM. |
12-10-2008, 06:26 PM | #14 | |||
Smile
12-10-2008, 08:39 PM | #15 | |||
Boost Addict
Mic
12-10-2008, 08:48 PM | #16 | ||
Smile
I have the info for our cars wiring. On the holdens I know that from my installation work that pink is the ignition and the other wires i can work out .
I hope it makes a difference..
16-10-2008, 11:44 PM | #17 | ||
Im interested in what your trying to do Stav, and updates?
16-10-2008, 11:58 PM | #18 | ||
Smile
Got a price on the coilpacks from a holden wrecker...the price was far better than I expected. 120 dollars for the set. I may need a stronger spark to burn the excess oil slipping past my oil rings lol
17-10-2008, 12:06 AM | #19 | ||
Smile
Now lets see if the car runs at all with them.Lets see if I burn my computer
17-10-2008, 12:29 AM | #20 | ||
Boost Addict
if its all wired up right, it wont burn nothing
its just a series of switches ;)
18-10-2008, 11:15 AM | #21 | ||
Smile
Sorry for the slow progress guys..Just havent had time to get this happening. I am focusing on my work.I am going to become number 1 very soon down here. eheh. Feeling great and taking no prisoners..lol
Wont be long though that Ill have the hot little coils in my hands.In the meantime I may wire a new loom from the ecu so it makes the installation quicker. The only issue is mounting the coils...but I will sort when Iget a second ..
18-10-2008, 05:25 PM | #22 | ||
Boost Addict
haha ... no worries mate
let me know if ur supplier has a few more Ls1s lying around, i always need them, got two more coil conversions coming up over christmas
18-10-2008, 05:54 PM | #23 | |||
Smile
18-10-2008, 07:34 PM | #24 | ||
Boost Addict
i prolly start with another lot of 8 (two 4 cylinders)
18-10-2008, 10:27 PM | #25 | ||
Boost Addict
unless he wants to make a deal on two sets
18-10-2008, 10:59 PM | #26 | ||
Smile
i was quoted on six coil packs. I will haggle for 16..
19-10-2008, 10:30 AM | #27 | ||
Boost Addict
haha, no worries
