22-11-2008, 07:27 PM | #31 | ||||
Afterburner + skids =
Seriously, good that they acknowledged their mistake. Also good to see the tried and true method of blaming the guy who doesn't work there any more is still going strong!
22-11-2008, 07:38 PM | #32 | ||||
Back to Le Frenchy
As for blaming the "ex-employee", I can understand that. You don't ever want to tell a customer that the bloke who made such a screw up is still the one doing the work.
22-11-2008, 07:48 PM | #33 | |||
22-11-2008, 08:00 PM | #34 | ||||
Back to Le Frenchy
Anyway I won in the end, the way I like it.
22-11-2008, 08:04 PM | #35 | |||
23-11-2008, 02:50 AM | #36 | ||
Don't get me wrong i like loctite and all. BUT......
Loctite melts when hot, it then forms into thick lubricating oil like substance again, you know the sort of substance that helps do up and undo bolts, just like when it came out of the bottle. Read the full instructions, somewhere you'll find a if you can't get bolt undone afterwards heat the bolt. Loctite to remain good should be kept in the fridge for a reason. I have never pulled a set of calipers off to find any thread locking substance on the bolts and i spend around 15 hours a week in a tyre/suspension workshop - my mornings. The bolt that is use is an intergral locking washer bolt on them, it is not suppost to need anything to lock it up. (and i actually make bolts for a living every night, come visit me in the workshop if you like i get very bored). And my final remark is that ford do things for a reason, nearly everything in our cars is done from some sort of research and development. Once again i've never seen a pair of calipers pulled off a under warranty car to have thread locker on the bolts. So in saying all these things, you guys make up your own mind as to wether or not to thread lock them, personal i don't, i just do them up to a bit over correct tension. Which is where i think you'll find the person who touched the bolt on your car last russell, went wrong. Either way it was their fault. RANT off.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
23-11-2008, 12:05 PM | #37 | |||
Miami Pilot
23-11-2008, 12:17 PM | #38 | ||
JC i take that full into suggestion that it could be on there, i just have not seen it. It is in fact highly likely, i cant remember ever taking bolt out of a caliper and actually looking for a form of loctite on their.
But as for calipers getting hot and melting it, the temp to melt loctite and so on actually isn't that hot, somewhere around 100c, and I can see it feasible that your caliper would get that hot at times. The whole point i am trying to get at here is that if ford do or don't put it on from factory on a bolt it is done so for a reason. And what i do know for sure is my last pad change on my AU was done by a ford workshop, a very reputable one, and there is absolutely no sign of any previous thread locking substance on my retaining bolts.
23-11-2008, 12:27 PM | #39 | ||
Critical Thinker
Russ, you are a lucky mofo. Im real glad everything turned out well in the end. This is a good warning for all of us out there. Ya just cant take things for granted. Whether you loctite or dont, its up to you, the driver to feel confident in the work under taken. After all its piece of mind if your confident in your braking system to pull you up satisfactorily when needed. I too go with the motto, 'Its better to be safe, than sorry'.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
24-11-2008, 01:11 AM | #40 | ||
Russ,you are one lucky man for sore.With this near miss, i would like to ask you guys the following question which i was going to ask before reading this post as i need to replace my front brake pads.In my Gregory's service manual under the heading ' it has the following warning
24-11-2008, 01:21 AM | #41 | ||
Sorry guy's computer went funny with bad weather, The warning: "On AU series 2/3 do not re-use caliper guide pin bolts.These bolts have a special adhesive coating that is damaged once they are removed". Do you guy's replace them and if so can you only get them from ford?
Thanks Steve |
25-11-2008, 02:42 AM | #42 | ||
MR INCH
25-11-2008, 11:46 AM | #43 | ||
IWCMOGTVM Club Supporter
Had the same thing happen to me (in the hand me down Camry), except the caliper came off at 80kph going to a mates house. Still managed to nurse it back home. Found out that the mechanic (thats kept going on about safety) who did the work rounded the bolt and stuffed it up.
Daniel |
25-11-2008, 12:13 PM | #44 | ||
T3/Sprint8
JC you are spot on, having done my brakes many times myself I always b---h you need to undo the caliper bolts all the way with the ring spanner as from factory Ford use the yellow coloured loctite, well that was on my ex XR8 bought new and there's still bits left on my TS50 the last time I stripped my calipers.
If a so called mechanic neglects to put a some back on at refit sheer neglect and laziness imo. First thing I was taught being a brake specialist longlong ago. By the way Russell lucky boy as has been said and good the workshop has accepted responsibility.
25-11-2008, 12:38 PM | #45 | |||
Back to Le Frenchy
Just too bad it has caused uneven wear from being loose. Had a proper look at the rotors last night and found the passenger rotor to be ok but the drivers side (affected side) to be near on stuffed. Not so slotted anymore :
Looks like the brakes are going to have to be done a little sooner than anticipated.
25-11-2008, 12:43 PM | #46 | |||
Cane Farmer
Did you notice a sort of a “tick tick tick tick tick tick” noise before the bolt dropped?
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
25-11-2008, 12:47 PM | #47 | ||
Tribal Elder
Russ, you mentioned you would name and shame them for doing a shonky job, but how bout naming them for the rather friendly outcome.
25-11-2008, 12:56 PM | #48 | |||||
Back to Le Frenchy
Can't hear much over my engine at WOT Quote:
Mr Brakes - Howitt Street Ballarat.
25-11-2008, 12:59 PM | #49 | ||
When you did the brakes, were the rotors new to begin with? IF so, what did you use?
25-11-2008, 01:10 PM | #50 | ||||
Back to Le Frenchy
25-11-2008, 01:11 PM | #51 | ||
You going to replace them with the same then I assume? I'm in need of some myself is all.
25-11-2008, 01:15 PM | #52 | ||||
Back to Le Frenchy
09-01-2009, 11:45 AM | #53 | |||
Back to Le Frenchy
An Update.
Rang this morning to see if they had arrived, checked what they were and after a little hesitation he said yep we have them in stock already. I found that a bit odd as they aren't a real common part so I queried him on the part and they turned out to be the standard 287mm rotors he had. After a little discussion and a call back suddenly he has no knowledge of mine having the premium brakes, can't remember our 2 phone calls and the time I went in there and basically played dumb and said he can't do them for anywhere near the price he originally said. Real nice that is, initially deny fault. Then admit it, say you'll do right by me then when it comes to it give me a price that is over inflated above what I can get them for from any other retailer. So anyone from Ballarat I suggest that you steer clear of Mr Brakes if you value your safety.
09-01-2009, 12:26 PM | #54 | |||
It seems to be going around in circles with this bloke.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
09-01-2009, 12:27 PM | #55 | ||||
Treasure your balls?
. . . Quote:
Meteorite T3 TS50 ESS |
09-01-2009, 12:30 PM | #56 | ||||
Back to Le Frenchy
And I think a more appropriate name would be Mr......as a mod I will not try to avoid the swear filter.
09-01-2009, 12:40 PM | #57 | |||
09-01-2009, 12:44 PM | #58 | ||||
Back to Le Frenchy
09-01-2009, 06:07 PM | #59 | ||
Darn only just read this thread.
The images it put in my head were sickening. Could have ended in disaster very quickly. |
