Old 15-03-2009, 12:58 PM   #1
Mullett
Badly Focused
Mullett's Avatar
Default LS/LT spotlight install
I do a lot of night/country driving, and these were sitting in the shed...the rest is history. I don't like mounting lights on the front bar/protruding, especially on anything that isn't a 4wd, but there's a surprising amount of room behind the front grille...
Remove the top cover. The grille will have to come off eventually, but it's useful to have it in place now to check clearances.
Cut off this bracket
Cut two peices of 50x50x3 angle bar to support the lights, mark, drill and bolt them to existing bolt holes with M6 bolts and stainless nuts.
Cut a peice of 40mm flatbar to support the lights (I used aluminum because it was there)
Notch the support bar
Lights attached!
Use this wire to trigger your relay (NEVER run spotlights off the headlight wires...they'll melt)
Lights attached and wired up with the grille removed
Everything put back into place and ready to go!
This is pretty straight forward, the biggest peice of advice I can give is to check fitment at EVERY stage, you want all the covers to go back on neatly without interfering or rattling. Also, what works on my car might not work on yours...you might have different coloured wires, different stuff under the covers etc. The grille doesn't affect the lights too much, i've tried with it on and off.
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2009, 02:12 PM   #2
819_FLY
819_FLY's Avatar
Nice subtle and practical. I was thinking whether the grill would scatter the light a bit but you have answered the question hahaha.
The standard headlights even on high beam don't look enough light for me considering I make a cross country trek once a year on average and involves some night driving, could be an option for me to consider as the fog lights wont cut the mustard due to one being used for air pickup for the pod filter.
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2009, 03:36 PM   #3
Mullett
Badly Focused
Mullett's Avatar
Yup, foglights are pretty much only for very close range, they're too small and mounted too low to give any real long-distance illumination. The spotlights fill out the 'void' in the middle of the standard headlight range, giving about 300m of useable vision. They do reflect badly off roadside signs though.
-RM.
Old 15-03-2009, 04:19 PM   #4
DZFord
DZFord's Avatar
You weren't going for THIS look? Maybe a little more subtle! Should be handy for those country roads.
BTW, there is a fair bit of space behind that upper grille!
Old 15-03-2009, 04:53 PM   #5
819_FLY
819_FLY's Avatar
Yeah thats the spirit!!
Check out 819FLY!!
Old 16-03-2009, 12:12 PM   #6
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
I kinda wondered how or where someone would mount such things. Nice work.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2009, 02:51 PM   #7
Mullett
Badly Focused
Mullett's Avatar
Check out the lift on the front wheels in that pic!
-RM.
Old 16-03-2009, 03:03 PM   #8
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Quote: "Check out the lift on the front wheels in that pic!"
I believe that's pretty much standard gravel-spec suspension. The guards are far from stock in it's shape and it looks a bit funny but very effective. Did you see the photos of "our" WRC Replica we had at Small Ford Sunday?
BTW I've had past experience with fitting driving lights on my last rides but this time I decided to upgrade the globes and I'm very happy with the results. But that's a nice, subtle job there and it might give some protection from stones etc. Well done.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2009, 04:11 PM   #9
melbzetec
Old enough to know better
melbzetec's Avatar
Good job MUllet. Nice to see some custom fabrication work being done
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2009, 04:14 PM   #10
melbzetec
melbzetec's Avatar
Good job Mullet. Nice to see some custom fabrication work being done
Old 16-03-2009, 05:13 PM   #11
Velociraptor82
Eat my Brake Dust
Hey twice the praise!!!!
