Old 27-09-2010, 08:26 AM   #1
scottc
Default Column auto wont start in Park
Hi guy's,
I have a 99 AU ute with column shift auto, which is not starting in park anymore, only nuetral.
I can feel the gears go into park, but the electrical still thinks its in reverse (reverse lights on when in park)
I had a search but couldn't find anything on this issue. Feels like a switch of some kind?
Thanks for any help,
Scott.
scottc is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2010, 08:47 AM   #2
frd906
could be the neutural switch on the gear box it self, which is playing up
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2010, 08:59 AM   #3
bartsau
bartsau's Avatar
I have had the same problem on a wreck i bought a while ago. Starts fine in neutral but not always on park. I have not tried fixing it yet but the gear selector is just slightly out of adjustment. When i hold it further on the position of park or will start fine. hope that makes sense.
Cheers, Rhys
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 27-09-2010, 09:00 AM   #4
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
park nutral switch on the gear box its held on by 2 to 3 8mm screws its the white thing with 2 plugs going into it you cant miss it
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2010, 09:15 AM   #5
The Monty
Just slidin'
The Monty's Avatar
Loosen them, adjust it more forward and retighten. Its quite fun to do
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2010, 10:11 AM   #6
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
Linkage bushes could be worn and need replacing.
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2010, 11:03 AM   #7
scottc
Cheers guys,
will have a look and post results.
Scott.
Old 27-09-2010, 11:20 AM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
INHIBITOR switch guys. And if that is what it is, i have a spare new one you can have for the right price.
