Old 24-01-2011, 08:46 PM   #1
creative
I am Batman
creative's Avatar
Default 2005 fiesta lx
a quick question.
The above car kept shutting down at random times. Both hot and cold temps.
Speedo kept dropping in and out. Battery has been replaced, had the car on the diagnostics and found the speed shaft sensor to be faulty. This was replaced.
so my question is, would the ecu report a fault on the speed sensor and shut the car down? is this sensor used to help determine A/F mixture so if its getting no signal it shuts down to prevent damage?
thanks folks
creative is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2011, 09:51 PM   #2
Twinpiston
Finally rollin on 20's
Twinpiston's Avatar
I have heard of similar events resulting from a damaged ECU (a little common according to the UK folk)
Fiesta ST..... Colorado Red...... SOLD
Territory Turbo Ghia ..... Winter White
SOLD - Good bye my little buddy!!!!
K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs.
Twinpiston is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2011, 01:56 PM   #3
creative
I am Batman
creative's Avatar
Well the symptoms were very similar to when my ecu failed on the ute (heat caused it to cut out) but not knowing if the ecu using the speedo as a measurement to adjust the A/F ratio. it doesnt get that signal, therefore shuts down.
Can anyone confirm this?
Old 26-01-2011, 02:10 PM   #4
bms
Originally Posted by creative
a quick question.
thanks folks
We have a 2006 Feista and it does the same and I added an extra earth strap which fixed it for a while then came back.
Had my mate check it out and came up with the same faulty speed sensor so have bought a new one but haven't put it in yet as since he diagnoused it, it hasn't done it since
Has yours been good since replacing the speed sensor ?
bms is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2011, 11:20 PM   #5
creative
I am Batman
creative's Avatar
just a little update.
since having the sensor replaced the car has been fine. I guess that means it is directly linked to the ecu and caused the shut downs when its was not reading it.
Old 06-02-2011, 05:38 PM   #6
ads266
Default Price
How much was the new sensor?
ads266 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2011, 01:22 AM   #7
bms
Sensor from ford $150 got mine through a mate for $110 which was gen ford part.
Old 11-02-2011, 12:52 AM   #8
ads266
Thanks for that mate.
Old 11-02-2011, 01:26 AM   #9
csv8
csv8's Avatar
How hard to replace ? in case my dies..thanx
CSGhia
Old 11-02-2011, 11:52 PM   #10
bms
Best to have it on a hoist as it at the back sort of half way up the gearbox right near the exhaust so not real easy.
