20-11-2011, 09:51 PM | #1 | ||
I changed my diff oil today to see if it would get rid of the whine at about 80-90km/hr... it hasn't totally eliminated it, but the noise is softer now. Thought I would give it a try as it only cost me $25 for a couple of litres of oil, and I already had a hand pump.
Anyway, I got to wondering. How often should diff oil be replaced as part of routine maintenance? I'm assuming what I drained today is factory original, so it's done nearly 200,000km. It looked in pretty good nick, a bit darker than the new stuff, but no sludge or bits of metal coming out of the drain hole. |
21-11-2011, 09:50 AM | #2 | ||
rexnet
did it smell mega bad? promeams its fresh ish. mine was black and smet so bad!!!
21-11-2011, 12:43 PM | #3 | ||
Nah, mine was a medium-dark brown, it did have a smell but it was just like used oil smell around a farm... nothing too horrible.
In contrast, the TQ95 transmission fluid I topped up with the other day smells like cat pee. |
21-11-2011, 01:35 PM | #4 | ||
Forgot that I took a pic. It was a little windy that day. |
21-11-2011, 02:12 PM | #5 | ||
rexnet
wow. thats healthy.mine was mega black. if you have your hand/service manual that comes with the car it should say how often to change the diff oil. also what do you do wit the car? do you drive it hard or tow lots? might be worth using something a bit more then average oil if you do.
also something to remember do you need to use an additive? |
21-11-2011, 02:38 PM | #6 | ||
Mine is just used for relatively sedate everyday driving, no tow bar.
I don't have a service manual, but my Gregory's manual just says to inspect for rear axle oil leaks... no clues on when it should actually be replaced. The diff has been whining since I got the car 6 years ago @83,000km. I used this... looked around the area for diff/manual trans additives but couldn't see anything. http://www.nulon.com.au/products/Gea...ferential_Oil/ (I don't have LSD, but this can be used for conventional diffs too) |
21-11-2011, 02:54 PM | #7 | ||
rexnet
oh yeah looks the goods then!
how'd u fill it back up? beer bong it or? |
21-11-2011, 03:00 PM | #8 | ||
Flairs - Truckers Delight
rowan194, are you sure it's the diff? does the noise change whether it's power on or power off? does it change if the car is in neutral?
because i have a whine at 92-96kmh. i'm relatively certain it ain't the diff however, i think it's the planetary gears in the trans.
26-11-2011, 02:59 PM | #9 | |||
It was diagnosed by one mechanic as the drive shaft, and that was replaced (probably with a used one) under the dealer's stat warranty, which improved but didn't obliterate the noise. Another mechanic diagnosed it as the diff and wanted me to spend several thousand dollars for a changeover unit... I politely declined. One reason I changed the oil was that I thought at first glance the caked on crap you can see in the pic was leaking diff oil. I thought it was like grease rather than running oil which is why I thought it was leaking. Anyway, turns out it was just mud, and I now know that diff oil is a bit thinner than I thought |
26-11-2011, 03:04 PM | #10 | |||
http://www.supercheapauto.com.au/onl...spx?pid=284708 Gets a bit tedious after you've hand pumped in nearly 2 litres, but you don't have to do it very often... I also used this to check my trans level. |
27-11-2011, 08:48 PM | #11 | ||
rexnet
i bet my diff is louder. hahaha. makes some horrid noise's.
i got quoted $1600 for a new diff. i think im gonna look around to make sure its the diff 1st. |
28-11-2011, 09:49 AM | #12 | |||
60,000 klm for abit of track work 100,000 klm for normal Hope you flushed Cheers Steve
MainLube - Extreme Lubricants For Overdriven Machinery Mainlube 175 Synthetic Race Oil SAE 10w60 (engine) Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox) Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff) www.Mainlube.com.au |
28-11-2011, 11:07 AM | #13 | |||
28-11-2011, 11:57 AM | #14 | |||
28-11-2011, 01:03 PM | #15 | ||
Yeah my car displays the same behaviour, only a tiny bit of throttle is needed to invoke it, comes from the rear of the car. However i'd describe it as more or less the same as the trans whine through first. Which, if you listen, also sounds like its coming from the rear of the car.
28-11-2011, 04:12 PM | #16 | ||
rexnet
did you use the addative?
28-11-2011, 05:33 PM | #17 | |||
29-11-2011, 12:30 PM | #18 | |||
cheers Steve
