Old 15-11-2012, 10:31 AM   #1
tim_pato
tim_pato's Avatar
Default ded gas con rods.
Hi all as the search function does'nt work on my phone..... are the dedicated lpg con rods any stronger than normal? how would they go in a turbo set up? not a race car just a boosted work ute.
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2012, 10:35 AM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: ded gas con rods.
They're the same as every other AU conrod mate.. They didn't differ until the B-Series
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2012, 10:37 AM   #3
tim_pato
tim_pato's Avatar
ok, thought so, thanks.
Old 15-11-2012, 01:18 PM   #4
4ford
Oooh...I always thought that dedicated 6cyl LPG engines had XR6 conrods...
Are you sure?
Cheers...
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2012, 03:02 PM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
AU Gas Rods are the same or similar , BA dedicated get the Typhoon s
Originally Posted by Riksta
Old 18-11-2012, 08:43 PM   #6
tim_pato
tim_pato's Avatar
sooo, ba ded gas conrods for an au turbo setup?
Old 18-11-2012, 10:12 PM   #7
FGII-XR6
FGII-XR6's Avatar
Au2 6200 a rod assy - connecting, 4.0l dohc vct efi$54.25
ba6200 a rod assy - connecting, all 4.0 turbo petrol engines$52.35
ba6200 c rod assy - connecting, 4.0l dohc vct lpg$51.15
this is from the parts database . so the standard petrol BA/BF uses AU rods. this means turbo rods should fit an AU
[SIGPIC][/SIGPIC]
Rides:
Old 19-11-2012, 05:01 AM   #8
tim_pato
tim_pato's Avatar
cool thanks. what about the pistons?
Old 20-11-2012, 12:20 PM   #9
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
tim pato, the only difference between an AU petrol and an AU gas motor is the AU gas motor doesn't have the provision for the injectors. All other internals are the same. Top end too.
