30-12-2005, 06:14 PM | #1 | ||
[EBGLT]
What could possibly be wrong with my car? I have done everything!
Spark Plugs Leads Dizzy Dizzy Cap Rotor Button Injectors Fuel Filter Accelerator Cable When your at the lights it lags unless you take off with really small accel. Then gets up to speed and you give it the boot and it lags again and jolts and spits and coughs!!! What the f!@#? Shaun
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
30-12-2005, 06:15 PM | #2 | ||
its not a!
Flooded it mate.
30-12-2005, 06:16 PM | #3 | ||
[EBGLT]
Who knows flooded with money that what it is!!!!!
30-12-2005, 06:17 PM | #4 | ||
bad fuel where did you get it from
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
30-12-2005, 06:22 PM | #5 | ||
[EBGLT]
Some little private fuel joint in maribynong im having trouble with timing to any hints?
30-12-2005, 06:24 PM | #6 | ||
Performance moderator
Chack the TPS voltage? It should be under 1v @ idle and pregressivley go up to 5v @ wot..Check koeo.. Check inlet leaks or hoses off inlet etc...
30-12-2005, 06:26 PM | #7 | ||
OzECruisers Treasurer
Get a biger radiator
30-12-2005, 06:29 PM | #8 | ||
[EBGLT]
Is the mark on one of the front wheel things the timing mark and its supposed to be in the middle of those two thing that poke out of the block!
What a TPS? Whats the koeo?
30-12-2005, 10:52 PM | #9 | ||
possibly a faulty oxy sensor? My EA used to flat spot because of that.
30-12-2005, 10:55 PM | #10 | |||
AFF's 1st DM.......
throttle position sensor
Key On Engine Off
30-12-2005, 11:24 PM | #11 | ||
i think i suggested this allready, but it's not a blocked cat or exhaust ?
31-12-2005, 12:53 AM | #12 | ||
Alternator
Have you done a compression check or checked the vacuum hoses ?
31-12-2005, 01:32 AM | #13 | ||
I reckon its a vacuum leak also. I also reckon that you'll find the leak right near where the MAP sensor feed tube connects to the manifold. Check it out coz it sounds like a A/F ratio problem to me...
Brent |
31-12-2005, 02:52 AM | #14 | ||
yer that hose from the manifold allways get holes right next to the valve that's conected the the manifold wen i swaped a manifold of the one i was puttin on had that problem.
u sould b able to get to it fearly easy just have to feall for the right hose |
31-12-2005, 10:19 AM | #15 | ||
[EBGLT]
We did that map sensor thing with the hose and there was no leaks. Ill get a compression check done on it when it gets sent away on the 3rd and we have all checked the exhaust and the cat and there is nothing there either its internal/ electrical for sure im just leaving this one to a pro i have done my bit!!!
04-01-2006, 03:20 PM | #16 | ||
[EBGLT]
Thats it i have had enough boys shes gone to the mechanics today probably wont see her for a week or so hope i can have her back for the cruise!!!!
04-01-2006, 05:48 PM | #17 | ||
rofl copter
id say timing, or ur tps... one of the 2
GQ patrol.
.... thats all |
04-01-2006, 06:00 PM | #18 | ||
[EBGLT]
What do you mean by tps?
