Old 16-10-2013, 07:32 PM   #1
mcfly94
mcfly94's Avatar
Default Std.Shocker work with King Low, (AU3 Forte)
Hey guys, just a quick question, will standard height shock absorbers work with king low 35mm springs in the rear of a solid axle au falcon.
Reason asking as I have near new ones from my xf which will fit (use same part no. for standard)
If not ill just get new ones.
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2013, 10:36 AM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Default Re: Std.Shocker work with King Low, (AU3 Forte)
Should be fine with King Low. Same height spring as a XR.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
