Old 07-05-2012, 09:44 PM   #1
T2TICK4D
T2TICK4D's Avatar
Default adaptive shift ?
i just got a au xr8 and near the auto shifter it has a adaptive shift sticker what is it and how do i use it
cheers
TE50 T2
AU2 GHIA
T2TICK4D is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 10:02 PM   #2
Ausromeo
Default Re: adaptive shift ?
It learns your driving style and will shift accordingly. Google search will explain in depth
Ausromeo is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 10:02 PM   #3
nassi
The adaptive shift feature is controlled by the EEC which continuously monitors the the drivers throttle inputs to determine your driving style. It then modifies the shift feel to suit the driving style.
It can be manually programmed to select economy or performance modes.
To manually select the desired mode :-
1) stop the car, apply hadbrake and turn ignition off
2) Apply foot brake and move the shifter to : "1" for Performance
"2" for economy
"3" for adaptive.
3) Turn the ignition to (II) and wait for the airbag warning light to go off.
4) Move the selector to R. The ECON light will flash three times to indicate a sucessful mode change.
5) Return the selector to Park and start the engine. observ the econ light.
one flash indicates performance
continous illumination indicates Economy
no light indicates adaptive.
cheers
XR8 II ute auto Silouette
XR8 II ute manual Venom
66 Mustang Convertible
56 F100
nassi is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 10:47 PM   #4
BHDOGS
It's pointless basically and isn't worth a crumpet
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 11:58 PM   #5
T2TICK4D
T2TICK4D's Avatar
how come?
TE50 T2
AU2 GHIA
Old 08-05-2012, 07:36 AM   #6
nassi
Originally Posted by fordauute2000
how come?
You play with it once and then forget all about it.
56 F100
Old 08-05-2012, 09:06 PM   #7
Ride
Stay Classy ™
Ride's Avatar
Agreed. Had adaptive shift in the Ghia when the TS50 ECU went in, didn't notice a different between it and the 'performance' mode as far as performance or fuel consumption were concerned.
ESS, well, that's a little better but the novelty wears off after a while.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2012, 08:08 PM   #8
T2TICK4D
T2TICK4D's Avatar
I have no Econ light so I'm not shore
TE50 T2
AU2 GHIA
Old 09-05-2012, 08:33 PM   #9
SSD-85
Econ light will only appear on non-XR/T models by default.
Your XR has the Adaptive shift strategy by default. However other modes can be activated as nassi explained.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2012, 10:04 PM   #10
T2TICK4D
T2TICK4D's Avatar
Thanks mate
TE50 T2
AU2 GHIA
Old 29-01-2018, 08:26 PM   #11
Bluey04
Is it only on xr models or can it be applied on all au 2 and 3 s
Btw i have a au2 i6 xl ute
Bluey04 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2018, 09:51 PM   #12
TICKFORD220
2009 xr turbo,2004 fiesta
Try the instructions on the 3rd post and see.
Im curious now too,i had a bit of a play with it before on my xr8s.
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
