Old 09-03-2007, 09:52 PM   #1
JoesAu
JoesAu's Avatar
Default how CaN i get the Crank Pulley off??
ive un-done the bolt, bloody hard bastard. Any ideas off how to get the crank pulley off?? ive tried wedging things in but it doesnt look good at the moment.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 09:54 PM   #2
naughts
Hmmmmm Mulberry....
naughts's Avatar
Get a Pully puller. It will come off easy then.
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 09:54 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
you need a harmonic balancer removal tool..
even with the right gear you come across a few stubborn ones..
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 10:15 PM   #4
JoesAu
JoesAu's Avatar
do you have to remove the radiator to use that tool?? i dont really wanna drop the Aircon.
Old 09-03-2007, 10:17 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
yes it is best, but you wont loose your gas, the condensor can stay put,just remove the radiator and fans
Old 09-03-2007, 10:49 PM   #6
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
My puller has shorter bolts
Don't need to pull the radiator out, just fans.
Balancer only needs to move about 10-15 mm
Need to be careful with the spanners but so don't damage radiator, I put a peice of laminex down there, thin but strong enough to stop damage from spanners
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 10:52 PM   #7
REHAB
REHAB's Avatar
Make sure it pulls evenly, and not to one side, otherwise you will have a ***** of a time pulling it out!
REHAB is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 10:55 PM   #8
FS5
joesAu ,you need a special puller .the old bolt style ones don't work.coventry auto parts sell them for $150 od bucks.they are exspensive but you won't get the balancer off without one.if your in good with your local ford dealer/mechanic ,they might lone you one.
you can remove the balencer without pulling out the radiator, but you have to remove the thermo's
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 11:06 PM   #9
au2sw
Blown 5L coming
au2sw's Avatar
the reason the bolt was "...bloddy hard bastard..." is because they are tensioned to some rediculus foot/pound, not a hundred percent sure how much, but you will need a torque wrench to put it back on.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2007, 10:05 AM   #10
JoesAu
JoesAu's Avatar
its ok i have the toorque wrench. Im goin to shops this morning to check out if i can find that pulller othererwise we'll have to try sumthing else.
Old 22-10-2020, 01:21 PM   #11
Pen_Nomad
Default Re: how CaN i get the Crank Pulley off??
You need the special $200 tool.
I am stuck in the same position trying to get the harmonic balancer off.
Pen_Nomad is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2020, 01:45 PM   #12
Bill M
Bill M's Avatar
Don't pay $200, this one is $165 posted.
https://www.ebay.com.au/itm/G-G-Tech...-/172750203493
You can also pick them up cheaper if you hunt around.
Bill
AUII XR6 VCT ute
20 years and still going strong!
Old 22-10-2020, 08:28 PM   #13
falconhell74
falconhell74's Avatar
search - Bf Fg harmonic balancer tool new solution $8 +$30 - in the search on this forum
This is how I did mine it worked a treat
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
