27-08-2021, 11:22 PM | #1 | ||
Anyone know if a 1 inch spacer is to much so I can run taller rocker covers to fit stud mounts with an RPM2 on a efi windsor. Trickflow also do a 3/8 phenolic spacer but unsure if this will be enough.
2001 AU2 220 XR8 - Build thread |
28-08-2021, 01:34 AM | #2 | ||
The Destroyer
yeah the tps will hit the bonnet insulation with a 1"one an if you loose/have-a-worn-out a engine mount it will dent the bonnet in that spot, 1/2" fits. heres one, sorry for the ebay link https://www.ebay.com.au/itm/12MM-MAN...-/401415924165
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
28-08-2021, 09:30 AM | #3 | ||
Thought I would add some more context.
Looking at options for heads/cam at the moment. Looking at the AFR 165 pedestal mount but just figuring out what would need to be done to go with a stud mount 11r 190 heads combo. Main issue seems to be clearance issues with stud mounts.
28-08-2021, 10:04 AM | #4 | ||
Frankenford pilot
A little trick I learned years ago is make some dough, flower and water, or if you have blue tack or plasticine on hand. Roll it into a a length, cut it to the required height, 1” for a 1” spacer and put it on the highest point and close the bonnet. It will compress to show exactly how much clearance you have and won’t damage a thing.
Cheers Bretto 73 XB GT Last of the Big Ports |
28-08-2021, 04:07 PM | #5 | |||
30-08-2021, 01:43 PM | #6 | |||
Peter Car
Nearly all the aftermarket rocker covers are too tall, but the trick flow ones are a nice height to clear roller rockers, but not too tall to touch the intake manifold. |
