Ford farilane 11.97 v8
I have an issue with it I buy the car from Melbourne and had it delivered to me because my legs are no good to travel .now I have replace all the ingition parts Pick coil .. spark plugs cam sensor in side the did. And air flow meter ..hight tention leads . .. injectors. Did cup rotor button .. and still hard to strat the engine I need a bit help out here thank you god bless all |
Next upgraded Mk1 Leopard
what Seriously AU is it? Sounds like the wrong years
i keep having fuel pump issues so start there spesifically with priming
2001 Falcon Fairmont AU2 Big turbo coming Lsd |
Regular...with metamusal
![]() Join Date: Oct 2009
