#31 | ||
TL40 Wagon?
The XR6 Cam with a unichip or edit isn't a bad choice for a street auto car at all.
lots of mid range easy driving and yes i have seen them pull mid 140rwkw with good exhaust mods. the XR6 cam on its own just swapped for a stock cam is a bit ordinary worse idle not much more power. Fo a stock ecu car with decent extarctors and exhaust the dev3hl is a good look and it worked for me. As a rough rule of thumb for a falcon six you will have or should have 105rwkw extractors and exhaust will lift that to 115rwkw and most decent cams and I would say Joe at Crescent in Liverpool Sydney CMS stage 2 or Jim Mocks dev3HL are decent and will give 135rwkw or anither 20 WITH stock ecu! Unichip or edit add 10rwkw! |
#32 | ||
Smile
Joe at Crescent motorsports is a good choice for sure.Top bloke to deal with too.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#33 | ||
does Crescent motorsports have a web page? would like to have a look try and get more details. may have to call jim mock and ask as well.
#34 | |||
Built Ford Tough
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
#35 | |||
XB in parts...
Daily Driver 2019 Ford Escape...looking for XR6T's. |
#36 | |||
TL40 Wagon?
#37 | ||
TL40 Wagon?
Trans type is a critical factor in cam choice! I think its worth mentioning so i did.
#38 | ||
Built Ford Tough
My sig says I do.
#39 | ||
Built Ford Tough
I'll stick to the theory that without headwork, the dollars you could spend on cams are better spent elsewhere, especially if you have an XR6. Terry's 14.3 (his is an auto...) on dunlop sp 3000's is good proof of that too. Both of us have 95+ mph traps showing good power with stock bits.
#40 | ||
i wish i was not so lazy i got a Auto, driving in the city with a manaul is just a pain.
#41 | ||
i'd give jmm a call there gears expensive ,but it works .i installed one of there streetfighter cams in my au with the usual intake/exhaust mods and it made 140rwk and 159 after fitting a unichip .
also theres a guy rpd cams he's got some good stuff also .shop around there's alot of gear out there now for the i6 |
#42 | ||
The stall converter is a key issue when it comes to cams ... with a manual .. you can stall a car up nicely to launch ... but it you want that power/torque down low when launching an auto ... cam profile needs to be different from a manual ... also the dialling-in of the cam plays a massive part on where you want your torque to be within your rev-range.
Stallies also robs some power on dynos as well ... I think the larger the stallie ... the more power is robbed ... but all in all ... it comes down to on-road/track performance ... not really the rollers (whch should only be used as a tuning tool).
#43 | |||
Smile
