#31 | ||
Holbrookau, if it has ABS, and there's no fuse, the ABS light would be on.. It's not on, so it may not have ABS?
#32 | ||
Crawled under the car again, and the only other marking i could see on the diff (besides some sort of serial number i think) was a yellow sticker that simply said 4JF. This is starting to bug me!
Fusebox in engine bay definately looks like it's got an ABS fuse. One other question, and maybe i should start a new thread for this, but in the fuse panel by the dash - the top middle spot (unfused in my car) is marked CB 30A and S.A. SUSP. The manual simply says NO FUSE and doesn't give a description. Any ideas? Same with the T/S relay in the same fusebox...what's it do? |
#33 | ||
BLUE OVAL INC.
That would be self levelling suspension. as on Fairlane/ltd
If the ABS fuse is in but no light comes on you will proberbly find the globe has blown or removed as the abs isnt working and the light was removed to hide the fact. Check inside the rotors and see if the abs sensor rings are there. They look like thin rings with lots of holes in them and they are on the inside of the rotors. |
#34 | ||
My EB series II GLi wagon is an ex-police forensics runabout, marked OPT20 on the compliance plate. Features 2100(?)kg Reece factory towkit, and signs of the fittings inside for those early nineties car phones!
06 BF SR - Shockwave, JTG Liquid Injection duel fuel, K&N air filter, XR8 upper intake, F6 lower intake |
#35 | ||
FirstOnRaceDay
if you want to see if you have abs just drive along and slame the brakes on if you lock up no abs if you it locks then regainse traction(no skiding) then you have abs simple.
#36 | |||
#37 | ||
FirstOnRaceDay
ok suit your self... I guess if you end up not having abs it could be trajic... Like what happened to me when I went from the 94ED fairmont ghia to a 91 falcon GL forgot about no abs and went sliding down the hill(in the wet) towards the lights thankfully no one was there and I stop right befor the lines.
