#31 | ||
don't forget, transfering weight from the front to the rear has twice the effect of just removing (or adding) the weight at either end...
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#32 | ||
FTF Club Moderator
I don't believe it. How could you forget, something like a battery. If it was to be moved, it would be for a reason.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
#33 | ||
building the xe...
alfa spider has boot battery aswell, and its a pian in the ... trying to boost it, especially when you could earth it out on the body which is less than 10mm above the terminal...
yeah i cantimagine voltage drop being friendly trying to crank a 6l v8... |
#34 | |||
but in the end the task was abandoned due to cost. |
#35 | ||
love the quad cams
with all of the cad cam design these days, and supplier interaction - there is no way that it could be a design fault. If the battery is too big then the blow torche would be applied on the manufacturer of the battery to fix it.
#36 | |||
In between Fords
#37 | |||
Bring back Ambrose!
#38 | ||
1967 XR Falcon
My gf's mini has its battery in the boot!
#39 | ||
R33/R34 GTR/GTST had them in the boot I think.
#40 | |||
FPV-Tickford Club of NSW
#41 | ||
Is it a small battery?
I'm just going off picks I googled, it looks to me like there's a cover for terminals, but hardly enough room for a battery. |
#42 | |||
my mates R31 battery is under the bonnet also |
#43 | |||
In between Fords
#44 | ||
Makes it so much easier to get it out and to jump start cars! pft.
#45 | ||
Must just be GT-Rs.
![]() Doesn't look like too much room in there. |
#46 | ||
Dose it really matter where the dam thing is. I have spoken to two of the design group and one of the engineers and none of them now anything about?? So who gave you this so called inside info??
#47 | ||
Hmmmm
if the battery is in the boot, IF, it will be because holden want it there. If u are nieve enough to believe that they would forget it, you will believe anything. (V10 GTHO)
#48 | ||
V10 GTHO i must get one of those's.
#49 | |||
Automotive Designer
Do you know what kind of materials Holden has got a hold of for the new VE? I heard a while ago that there mabey a new type of steel/alloy employed for the safety cage in the new Commodore. Sorry guy's for getting off-track over the headline-grabbing news story about the battery location in the VE. Damn I keep running out of salt when I view these types of threads. |
#50 | ||
Meh if its in the boot its much better for puting in subs and amps and stuff
#51 | |||
1) Jaguar XJ12 from 1994 till the end (about 1998) had the battery in the ИИИИ end. These cars had a comparible electrical load to a more modern commo. 2) True, the XJ12 had a high compression 6 litre V12! Actually come to think of it there may be some validity in point 2, since a V12 has a far superior balance characteristic than a V8 added to the greater number of bangs per rev, theoretically should mean much less effort in firing them up thus less is required of the starting equipment. |
#52 | |||
Love the blue oval but we did have the Taurus, shudder shudder retch retch. only redeemable feature was you could opt not to buy it......
Twin turbo 363 xp hardtop Single turbo Tojo Dyna 302 |
#53 | |||
#54 | |||
Went to an automotive battery seminar a few years back and these guys prefer the battery in the boot, away from heat sources.
They reckon heat shortens a batterys life dramatically, and under bonnet temperatures keep getting higher. Vehicle manufacturers have tried to over come the heat by enclosing the battery & directing air onto it, but this is only a bandaid fix. High temperature cause an unwanted chemical reaction inside the battery and in extreme cases the electrolyte will boil, the gases emitted are highly corrosive & explosive. Quote:
EDIT: http://www.batteryworld.com.au/v1/Ba...0Batterie2.htm
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk ![]() Last edited by johnydep; 02-02-2006 at 10:55 PM. Reason: New link |
#55 | |||
#56 | ||
Sleeping Beast
Next they will put the engine in the boot and be calling it a bettle
#57 | |||
Boron - not sure that they've used it for the entire cage though, i highly doubt that. Plastics have been used a lot more in VE also. Haven't seen many new designs of yours lately - how about some Orion interpretations?? Give you a head start, think orion xr's even more agressive than current FPV's.. :evilking: |
#58 | |||
Automotive Designer
I was thinking along the lines of Boron being used, I know the euro Vectra uses it in the B-pillar and the Volvo XC90 has it in the roof supports - quite strong stuff. I've seen a few rollovers involving the XC90 and there is hardly any roof-crush as a result. I think more manufactures should be using it in there vehicles. As for the sketches - I must admit I've been a bit slack over the past few months. However I have been doing a few, including my take on a new AM DBS. I'm a bit ИИИИed-off though because since I completed that particular illustration, AM has come out with a sketch for the DBS that looks quite similar to mine in its proportions and greenhouse. As for the Orion, well I haven't really considered doing a interpretation of that yet - not sure where to start. |
#59 | |||
old fart
#60 | |||
On the falcon front - don't be surprised to learn that there will be safety innovations that stem from the volvo brand. |
