#31 | ||
THE Fairmont Ghia 75th
i have boston 6.5" splits and they seem to go pretty hard up front. i have the 5x7 model in the rear shelf for some fill too. they sound nice.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
#32 | ||
search this item number in ebay... 140484602584
this will allow you to use any 6 or 6.5' speaker. Not only do round speakers sound better but due to availability they tend to be priced $30-$40 cheaper then the 5x7 equivilent. Honestly at 15 bucks, you cant go wrong here |
#33 | |||
All Bran = Regular Member
I had to fiddle quite a bit to get my Type X's to fit. There is literally a cigarette paper clearance between the window at the rear and the speaker grill at the front. I made my own spacers out of 12mm mdf and then rebated the speaker into it, bit by bit. The Hertz's I had before the Alpine's were not quite as tight a fit. I probably had a millimetre to play with. It will depend on the mounting depth of the speaker. No such problems if you don't want to use the factory grills. |
#34 | |||
not here much anymore
RAM 1500
#35 | |||
It's a nice sound and all but a lot of mucking around. Mind you, the sound in the BF I had for a week sounded pretty ordinary but I think decent 5 x 7s would go a long way to improving that (not that I'm likely to end up in a BF...) |
#36 | ||
ROCKING THE EL FUTURA
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
#37 | ||
rexnet
I've herd stories about type R 5x7's fouling on windows.
#38 | |||
The latest Type R 5 x 7s have a 64mm mounting depth. My Type X 6.5" woofers have a mounting depth of 65mm and iirc the spacer is 5mm (or maybe 6mm) with a hairs breadth clearance between speaker and window. |
