30-09-2006, 11:39 AM | #1 | ||
Is anyone runnign E10? If so or if you have tried it, what do you think of it?
From what I understand: - higher octane rating but lower calorific value - slight drop in horsepower. - more corrosive - tends to remove fuel line depsoits => keep fuel filter handy when first used. Keep an eye on injectors. - high oxygen content => runs leaner. - engine could be a little harder to start. - slightly higher consumption. What is your experience with it? |
30-09-2006, 11:44 AM | #2 | ||
yeah ive used it, i bought it from liberty, i didnt notice mutch difference from using 95 octane fuel.car started normaly and fuel consuption was much the same.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG. |
30-09-2006, 12:29 PM | #3 | ||
Tuned @ Pitlane Frankston
what is e10?
anything from liberty can't be good |
30-09-2006, 12:32 PM | #4 | |||
30-09-2006, 12:35 PM | #5 | |||
Back to Le Frenchy
I only ever really use the united E10 Boost 98 in both the EL and AU. Get about the same economy and can't notice any difference in power, although the AU seems to ping less (poor tune) when it's running on it.
30-09-2006, 12:51 PM | #6 | |||
I'm also wondering just how economical it is. I can get it up at Coolongatta at Freedom fuel but I haven't checked out the price yet. |
30-09-2006, 01:27 PM | #7 | ||
Oops, I slipped....
E10 also has a higher percentage of oxygen in it, therefore the stoich ratio is slightly lower than the 14.7:1 for regular petrol.
There was an article in Street Machine a few months ago about it, they tried E10 in an LS1 Commodore, and found nearly all of the advantage came after they re-tuned the ECU.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
30-09-2006, 01:35 PM | #8 | ||
As a test I ran Boost 98 in my ute back to back at Calder. Versus Optimax it was consistantly down 2-3 MPH. That says it all I think.
I could feel driving it that definately wasn't as sharp as Opti. - John |
30-09-2006, 02:44 PM | #9 | |||
The higher grade fuels often have a higher calorific value as well as a higher octane rating. Higher octane fuels can also burn slower. |
30-09-2006, 02:53 PM | #10 | ||
Now XR8TickfordBoy
Ive used the United Servo brand of E10, cos it's 4 cents cheaper. I find without any real evidence that the tank goes alot quicker, go for a cruise and a quarter of ya tanks gone. At the end of the day I think its worth investing the extra 4 cents per ltre for standard 95oct cos it lasts longer. May be good to use every now and again to help keep fuel lines clear but other than that I dont think its worth it. Petrol companies only make it cos it cuts their costs and they make a higher profit margin off it! 10% less to make it, but 4 cents at the pump is only like a 5 or 6% discount!
EF XR8- Respray in Monza Red with Clear Coat, Custom Rear Bar, AU V8, EL GT MAF, Rebuilt and Strengthened Auto with Stage 2 Shift Kit, 2,500RPM Stallie and tranny cooler, Rebuilt Diff with 4.11 Gears, Custom Radiator, King Ultra Lows, Pedders Shocks, NL Concorde Rims. |
02-10-2006, 01:57 PM | #11 | ||
never enough power
I've been running the Shell Extreme (100 octane, 10% Ethanol) and my EA likes t even more then the Opti 98, or Boost or what ever the hell they are calling it now. It has helped a little bit with my pinging issues and economy is maybe a little bit better then the Opti 98.
EA Fairmont Ghia sleep: EA bottom end, AU tickford XR6 head JMM DEV 5, Race series headers, 5-speed manual, 3.7 LSD diff, sports suspension, sports brakes, all rapped up in a 89 champaign coloured falcon gl shell. |
