31-10-2006, 04:38 PM | #1 | ||
My cars playing up again, similar to how it was at the start of the year. Its developed a steamtrain kind of exhaust flow, where it kind of putts along in short outbursts of exhaust air.
This morning it hardly started and once i got it going there was white smoke coming out of the exhuast for quite a while, not normal condensation smoke.... I filled up with Bp Ultimate yesterday morning, and ive done 100k's since i filled up. A mates dad said the ultimate may have cleaned something out thats caused a block in one of the fuel injectors, could this be the case?? Any advice would be a huge help as the car can not be taken out because it feels like it wants to stall when it idles at the lights. Thanks Paul Last edited by crannersEL; 31-10-2006 at 04:49 PM. |
31-10-2006, 05:26 PM | #2 | ||
likes falcon's
white smoke= oil i think
is your car idling nice? (what are your leads.plugs.rotor button like?)
www.carhubsales.com.au |
31-10-2006, 05:31 PM | #3 | ||
White smoke is water IIRC and blue smoke is oil.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
31-10-2006, 05:45 PM | #4 | ||
hope its not a blown headgasket :S sounds like the symptoms of one....
31-10-2006, 05:48 PM | #5 | |||
31-10-2006, 06:18 PM | #6 | ||
rofl copter
white = water or its just really cold wereva u live :P
GQ patrol.
.... thats all |
31-10-2006, 06:43 PM | #7 | ||
Virtuous Bogan (TM)
Could be HG, is water coming out of the exhaust? Or just the steam?
BTW, ive never heard of an e series being 100%
31-10-2006, 06:56 PM | #8 | ||
likes falcon's
you're talking about cars in general al...
31-10-2006, 07:25 PM | #9 | ||
Its drinking water like there's no tomorrow, had to fill up the coolent before because it was almost empty, considering it was over half full at the start of the week. The Idel seams to be okay, its really reall weird.....
31-10-2006, 07:27 PM | #10 | ||
Virtuous Bogan (TM)
fill the water up and go for a drive, it definately sounds like HG from here, if it chews through the water then get on ebay and look up what EL XR heads are going for...look at the positive!
31-10-2006, 07:27 PM | #11 | ||
Oh no, really sounds like a head gasket :S
31-10-2006, 07:32 PM | #12 | ||
Its allready done a HG, how often do they blow??
31-10-2006, 07:37 PM | #13 | |||
Driplets of water, and heaps of white smoke..... Dads going nuts, saying its not HG : |
31-10-2006, 07:57 PM | #14 | ||
best way to tell is pull out the spark plugs (it will most likely be number 6 which is leaking) and if the plug is brown it means water has been getting in there. basicly the cylinder will get water in it making it hard to start and the steam out the exhaust is because there is water getting into the cylinder.
31-10-2006, 08:20 PM | #15 | ||
Shoot.
Another vote for the headgasket.
Head off, clean it up, heavy duty springs, big cam, AU gasket :sm_headba
20V Turbo |
31-10-2006, 10:35 PM | #16 | ||
Confirmed Head Gasket, getting towed to the shop tomorrow for a repair.....
31-10-2006, 10:43 PM | #17 | ||
Parts bin special
Bad news, typical e-series. Hope that will be the last one.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
31-10-2006, 10:49 PM | #18 | |||
That sucks Paul. When was the headgasket last replaced? Was it done on the cheap?
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
31-10-2006, 11:01 PM | #19 | |||
XR6 Turbo FTW
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
31-10-2006, 11:09 PM | #20 | ||
Parts bin special
It can really vary. My uncle's EL has done 200,000 and has already blown two while my EAII blew it's first and only headgasket at 230,000. My parent's EBII has also done about 230,000 and hasn't blown one.
31-10-2006, 11:48 PM | #21 | |||
01-11-2006, 07:17 PM | #22 | ||
Heres the car going for a ride this morning, this way saves petrol i guess.....
01-11-2006, 07:25 PM | #23 | ||
Are u getting some headwork while its off?? Good old port and polish job...
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
01-11-2006, 07:28 PM | #24 | |||
01-11-2006, 07:36 PM | #25 | |||
ORSM FORD CRUSIERS
damn that blew quick !!! they must have done a shitty job. go with the AU gasket option as everyone seams to be going this way and hoipfully it will last more than 45,000k
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
01-11-2006, 07:37 PM | #26 | ||
how much is the head gasket costing you to replace labour inclusive??????
Mine hasnt done a head gasket yet 230000kms....... touch wood |
01-11-2006, 09:32 PM | #27 | ||
I saw CRANRS in pieces today, almost brought a tear to the eye :(
Hopefully she'll be back and cruising better than ever soon |
01-11-2006, 09:43 PM | #28 | |||
01-11-2006, 09:53 PM | #29 | |||
01-11-2006, 09:54 PM | #30 | ||
Riding The Lightning
where you getting it done cranners?
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA |
