Old 26-10-2005, 12:07 PM   #1
NZL10971
Unhappy AU XR6 - rotational noise or squeak after new brakes
Hi Guys, have a very annoying problem appeared recently which has a few mechanics scratching their heads -(
Pads and Rotors changed, all checked by same outfit and mechanic that has serviced the car for the last 4 years no problems... now we have a type of squeak that can realy only be heard if running at 100km's along the motorway against a barrier to get the sound to bounce back at you. It would sound like it's coming from the R/F wheel or brake assembly, the noise stops when applying the brakes... (have checked handbrake - no difference) we have since gone through 2 more sets of rotors and pads, new calipers etc, coils and shocks checked... driving us NUTS !! please help..
NZL10971 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2005, 01:47 PM   #2
JC
JC's Avatar
Wheel bearings?
Ford Performance Club ACT
Old 26-10-2005, 01:52 PM   #3
jcxr
Tribal Elder
jcxr's Avatar
Split pin retaining the w/bearing rubbing on the dust cap?
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2005, 01:56 PM   #4
NZL10971
Originally Posted by JC-XRWgn
Wheel bearings?
Sorry, meant to say we have also had the bearings done at the same time..
Old 26-10-2005, 01:56 PM   #5
NZL10971
Interesting one... will check this out.
Old 27-10-2005, 11:36 AM   #6
Engineer
Cookie Monster
Engineer's Avatar
Default squeak
Hi guys,
This squeak can sometimes come from the contact between the pad and the caliper. There sometimes is a bit of movemnet which makes it squeak. When you apply the brakes the movement is stopped by the pressure of the piston.
There is a CRC product called "Disc Brake Quiet" which you apply to the back of the pads to eliminate this. Check out the link below for details..
http://www.mz3.net/articles/241.html
Engineer
Engineer is offline   Reply With Quote Multi-Quote with this Post
