Old 26-12-2005, 12:37 AM   #1
gardo
Default Replacing Transmission.
I am hoping someone can give me some advice here.
I have a 1988 LTD and need to do a tranmission exchange.
I have an EA with a good transmission and a poor motor, I am intending to take the transmission out of the falcon and put it into the LTD.
They are both three speeds.
Is there any thing that I should know before I get started?
What parts, seals, gasklets etc should I get first?
What problems am I likely to have?
Any advice from anyone who has replaced their transmission before would be appreciated.
cheers Roy
gardo is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 02:40 AM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
The swap will be quite easy.
Parts:
Pan gasket and filter for the new trans
15L of Dextron3
Problems:
none really, very easy swap
Also, if your engine rear main seal leaks this is the perfect oppourtunity to fix it.
Old 26-12-2005, 10:32 AM   #3
tango07
Plus while the transmission is out put in a brass welch plug .
tango07 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 04:57 PM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
It wouldn't hurt to replace the front trans seal while its out. They can harden if they haven't been used for a while.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 05:35 PM   #5
LUXO_8
windsor user
the only thing that might be an issue is if the EA is CFI. (centerpoint injection)
the CFi cars had a different kickdown cable to the multi point cars....
