08-11-2009, 10:46 AM | #1 | ||
BA Mk2 Fairmont
I noticed yesterday that when I turn into a car spot and turn the wheel slightly the car shakes/vibrates. It probably shakes for a second or two. Ive also noticed that when I'm stopped at a light occasionally it would shake/vibrate as well.
Anyone have any ideas on what could cause this? Cheers |
08-11-2009, 11:00 AM | #2 | ||
power steering pump
pressure switch never heard of this before speacially when idle at the lights, will keep a eye out on this thread
08-11-2009, 11:10 AM | #3 | ||
Flairs - Truckers Delight
How many revs are you doing at the time?
With a dirty ISC/Throttle Body you will notice a dip in revs when slowing down or turning at low/no speed I don't believe you're meaning rack rattle.
08-11-2009, 11:13 AM | #4 | |||
BA Mk2 Fairmont
I cleaned the ISC and TB several months ago. Ill give them a clean today. Not sure what rack rattle is. Last edited by GT88; 08-11-2009 at 11:24 AM. |
08-11-2009, 11:24 AM | #5 | ||
Rack Rattle is not common in falcons, it's more usually a commodore thing
its where you dry-steer and you get the front end jumping about slightly hard to describe
08-11-2009, 12:36 PM | #6 | ||
BA Mk2 Fairmont
Just came back from a drive. When in P revs were at 800. When idling in D it was at 600 and when it vibrated as I parked it dropped to 400 for a second then back to 600.
Possible vacuum leak? BTW are those revs above in P and D normal? |
