Old 24-09-2008, 12:52 PM   #1
More revs
Default Mod time LS Zetec
Don't you hate the sound of crunching plastic and tearing metalwork when all you do is reverse into a concrete pole.... sheesh I'll take this opportunity to repair all the little parking lot dings and scrapes too.
While I'm at it I have a cat back free flow exhaust going on @ $420 plus fitting not bad for a stainless system.
One question tho has anyone compared a pod vs just modifying the std airbox? I mean there's some gains in removing the snorkel / silencer from under the guard but are there more gains in simply junking the whole airbox and running a pod.....?
Hmmm....
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2008, 07:00 PM   #2
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
You would more than likely run into issues with the engine only being able to intake hot air from the engine bay, unless you live in canberra.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2008, 07:21 PM   #3
Mullett
Badly Focused
Mullett's Avatar
A pod in the engine bay will send you backwards fast, even with a heat shield. Fitting a pod into the airbox and running CAI from infront of the radiator to the bottom of the airbox would be good, apart from the pod that's what I've done with mine. I'd think that a good panel filter and CAI would make the same power as the pod, but i could be wrong...sure sounds better with the airbox off
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2008, 07:41 PM   #4
RJO89
EuroFordClub
RJO89's Avatar
Remove the entire stock intake system. Get some aluminium piping and a few silicon joiners/elbows, then run the alu pipe from the throttle body down to behind the fog lamps. Then fabricate a heat shield and screw it onto the chassis between the engine and the pod filter. Minimal heat induction, and a great pod filter roar!
Far from stock... --- SOLD :
Old 25-09-2008, 10:05 AM   #5
More revs
I like that but how easy is access to clean the filter? looks like I would have to remove the bar..
Old 25-09-2008, 10:49 AM   #6
RJO89
EuroFordClub
RJO89's Avatar
Nah just take the front passenger wheel, take the inner guard off, then de-clamp the filter. Wouldn't take any more time than replacing the current filter.
Old 25-09-2008, 01:01 PM   #7
Mullett
Badly Focused
Mullett's Avatar
Yup, I'd agree with that being the best solution, if not the easiest. Just for gods sake, don't buy piping from retail stores like Auto one in those little monza packets. it's expensive. Just find a piping supplier in your area and buy from them, 2.5 inch 316 stainless bends are about $22 each...
-RM.
Old 02-10-2008, 10:58 AM   #8
More revs
I have the exhaust on now, as expected absolutely no diff in power but the sound is wonderful... I can hear the thing now and might stop stalling it.
The piping for the inlet gets looked at next week then into the panel shop for final repairs.
Old 02-10-2008, 11:12 AM   #9
Mullett
Badly Focused
Mullett's Avatar
*coughturbochargercough*
-RM.
Old 02-10-2008, 12:03 PM   #10
BlackLS
yum
With the exhaust, any change to the manifold/cat?
2005 LS Focus LX
250,000kms.
Old 02-10-2008, 12:54 PM   #11
More revs
No BLS just a simple bolt up to cat job. I was only after a voice. I think some gains are lurking on the inlet side though.... coughturbocough..... not a bad idea actually..
Old 02-10-2008, 01:08 PM   #12
Mullett
Badly Focused
Mullett's Avatar
if you're going to make it go, might as well make it go HARD
-RM.
Old 02-10-2008, 01:44 PM   #13
BlackLS
yum
Turbo without the cat would be excellent: click here
2005 LS Focus LX
250,000kms.
Old 02-10-2008, 04:47 PM   #14
More revs
On the way home I noticed it does seem more eager until it slumps at around 5500.
I kept up with a 5l VS commodore easily until the second third change up when he took 3 car lengths and wouldn't give them back.
Yeah I think the inlet is in need of some tinkering now.
Old 02-10-2008, 04:49 PM   #15
More revs
Oh THAT cat.
Old 02-10-2008, 04:49 PM   #16
More revs
My ex wife has a face like a cats butt
