The Villan
I was wondering, since I am only allowed 6's (p plate restrictions), buy an AU xr6 (manual) and once I reach full license status, put 5.0L 220kw Windsor in.
Things I am sure I will need is - XR8 exhaust - XR8 ecu - Of coarse the engine - Engine mount/bracket? (not entirely sure) Talking some people and they suggested a different driveshaft is needed, possible diff change and a gearbox recalibration.
New addition! 2010 FG XR50 Turbo in Lightning Strike The PX Ranger has arrived! XLT Metropolitean Grey Previous Ride - 2007 BF MK II XR6 in Lightning Strike
Id just save the pennys and buy a xr8 when ya off ya plates, unless you keep the 6 and turbo or super charge it,
Shame Holden, Shame
Mate anything and everything is possible.
Some things just aren't worth the trouble/money. May get hairy trying to get it roadworthy/insured too. Just sell and get an XR8. Course this wouldn't be an issue in Tasmania, just get the XR8 to whilst on your P's ![]()
Essendon FC '11 EFII "XR8" Fairmont V8 185KW ELII XR8 engine, box & exhaust|Dual Fuel|Tints|FTR's|Factory bodykit |K&N panel filter|Interior LED Conversion|Leather steering wheel|Slotted rotors|Ghia wood + chrome|Subwoofer| ![]() ![]() |
Depends if you want to do it legit or not. I am planning to put a v8 into my wagon and have been looking into it. I'm not too sure about NSW but in VIC I will have to get it engineered. Some of the things they will require me to change are brakes (v8 equivilent or better), same for the suspension and then there i beleive the input shaft on the 6cyl is smaller than the v8 gearboxes. (Someone correct me if i'm wrong) The list goes on and on. I would definately suggest you save and buy a V8 falcon to avoud all of these problems. I would buy a V8 wagon if only there was more that a handful of them, rather than trying to get it registered after converting it.
That is my 2 bobs worth, hope this helps to shed some light on it.
Toy Car Build |
![]() Join Date: Nov 2007
correct on the shaft.
#6 | |||
Back to Le Frenchy
What I can think of that you'll need are;
Engine (obviously) Gearbox - different input shafts Driveshaft - from memory they are different ECU can be retained and reflashed Front springs I'm pretty sure are different Exhaust - extractors to tips Steering - pretty sure the racks are different as is the intermediate shaft Electrical - looms are different Cooling - radiators are different I'm sure there's a few other issues you'll run into too, such as vacuum lines and heating/cooling control. Also the engineering of it will cost and the K frame's are likely to be different. It'd be a lot cheaper and easier to sell the XR6 and go to an XR8. With the money saved you could spend a bit on making it a bit quicker too.
#7 | |||
![]() Had a quick look then though and couldn't seem to find it. Was asking too much though around 11k I think.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
GT
yes mate this is very very possible . you can do it all over the phone and on the net if you like . all you have to do is convert the $$$. its called sell and buy.
#9 | ||||
I have wrecked a V8 and 6CLY ute and i'm 90% sure they both had the same 'k' frame.
Toy Car Build |
#10 | |||
I miss my wheelbarrow
![]() Join Date: Jan 2005
The only genuine reason I can see is if you wanted to retain a Manual trans with a Live axle in an XR package... that has some appeal. Daniel |
perhaps if you are going ahead with it you could buy a written off xr8 as a donor car, my young brother does this sorta stuff ALL THE TIME
#12 | ||
The Villan
Read all suggestions and thought stuff it, save money buy an fg xr8 when get full license. But knowing me my decision will change in an hour.
XB,XF,ZL,EA,EL,BA,SY,SZII
It's been more than an hour, so in case you've changed your mind, I'll add that I'm pretty sure that the diff is different too (the ratio at least).
Please don't do this! You'll be turning an XR6 into something that is neither an XR6 nor a genuine XR8. And it's a lot or work.... And it's more expensive.... As others have said. |
#14 | ||
Just slidin'
Im going to go against the grain here.
Get the XR6 and keep it clean. Save up a bit of money and when a S3 XR8 comes through the auctions written off, snap it up. I saw a nice one up here go for $2500 last time, leather and all. You have a couple of years to strip the car, sell off bits you dont want/need, learn how it came apart and document it all, keep all nuts in snap lock bags, and label them, etc etc. When you can, take a week off work, and do the whole lot, engine, trans, brakes, diff, tailshaft, etc. Youll learn a heap, it wont be hard to get it engineered, as you will have everything from the XR8 anyway. The best part will be how much you will learn. Then you can sell off the XR6 stuff, and probably make your money back on buying the XR8 donor car.
MD Mondeo - For the family
#15 | ||
Oh, a training objective. I can see some merit in that.
#16 | |||
Flairs - Truckers Delight
#17 | ||||
#18 | ||
Just slidin'
Either way would be good, but I would rather use a good base, and add better parts, then a broken base and add decent parts if you know what I mean.
Trust me, I learnt the hard way.
#19 | |||
The Villan
#20 | ||
Boss 27
Hey guys, I forgot how to start a new thread so I'll just post here.
Is it possible for a BA Xr6 to be converted to XR8? Your probably thinking It's a stupid Idea but I like the options that I have in my XR6 like the sunroof, Premium sound etc. So I don't really wanna get rid of the car. Any help is appreciated, thanks in advance Bus.
2003 BA XR6 Blueprint, Premium Sound, and SUNROOF!!! BF GT Front bar. |
#21 | ||
the other things that will be an issue is no IRS and no traction control the traction controll need all the rear brake pipes from the ABS back replaced and all the wiring harnesses in the car from the dash to the fromt of the car replaced a huge job
and with the IRS I don't think you can just bolt in an IRS cradle I think the mounts are different
[SIGPIC][/SIGPIC]
#22 | |||
