Old 07-12-2022, 03:44 PM   #1
EskyLife
Default Inertia/Retractable rear seatbelts for Mk2 4d Escort
Hi guys,
Has anyone fitted retractable rear belts to a 4 door mk2? If so what did you use and did you need to make any modifications to the car or the belts to get them to work?
One of my rear lap/sash belts is a bit buggered, and if I'm going to replace them it would be good to put retractable one is to make it a little safer for the kids.
EskyLife is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2022, 04:30 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Inertia/Retractable rear seatbelts for Mk2 4d Escort
Originally Posted by EskyLife View Post
Hi guys,
Would you have to get that engineered if it wasn't standard from the factory?
Old 07-12-2022, 07:58 PM   #3
EskyLife
That's a very good point... I thought that if it was using the original lap/sash mounts, that fitting newer belts wouldn't require engineering... But maybe the change from static to retractable would?
Old 09-12-2022, 11:44 AM   #4
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
the upper mount points on the parcel shelf should be strong enough so no need for engineering, but I found that it was incredibly difficult to mount the retractor there at the top because the shelf sits lower than the top of the rear seat. You will need some kind of dogleg bracket to lift the retractor up a bit.
I didn't even consider fitting the retractor at floor level but that might be a possibility.
I gave up and refitted static lap/sash belts in the 73
simon varley is online now   Reply With Quote Multi-Quote with this Post
