Old 04-03-2007, 11:02 PM   #1
finnyman
smoke rubber, not crack
Default Upgrading the fuel system
hey guys, ive got an EL monty, mods so far are R6 cam, crane valve springs, rollmaster cam gear, 2 1/2 inch lukey system (put off extractors cuz may be goin turbo), EL GT intake, k&n filter and shiftkit.... i want to know if there would be a significant increase in power if i added bigger injectors, fuel pump and regulator to this setup? and would the stock ECU adjust to the new fuel system?
finnyman is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2007, 11:21 PM   #2
snypereb
[EBGLT]
snypereb's Avatar
bigger injectors would definately help if you are going to turbo it.
[EBGLT]
Old 05-03-2007, 10:15 AM   #3
finnyman
would the ECU adjust though with the injectors,fuel pump and regulator?
Old 05-03-2007, 04:07 PM   #4
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
no it would not. u would run very rich down low i would say. but run fine at WOT.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2007, 04:58 PM   #5
webby_191189
low wagooon
Should make a nice little power gail and u might notice the fuel bill go up a bit to. But hey with perfomance comes money.
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2007, 05:03 PM   #6
EA2BA
PM me if you want
EA2BA's Avatar
Put it on the dyno and see what the problem areas are before upgrading anything, as said i agree abd suspect you will run rich and achieve very little except more fuel usage, a rising rate fuel reg set more towards top end could be a better option.
Old 05-03-2007, 05:04 PM   #7
Gunns
Gunns's Avatar
You could do the fuel pump and fuel reg now, but the ecu wont like the bigger injectors. You need a fuel pressure gauge so that you can set your max fuel pressure with the new adjustable reg.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2007, 07:07 PM   #8
finnyman
yeh there is no prob with the fuel system now i was just lookin at more performance, and if the ECU wont adjust and run too rich, i dunno... instead of gettin a full plug and play ECU, can u get a cheaper tunable chip that would suit this, rather then fork out for a new Haltech or wolf?
Old 06-03-2007, 02:15 PM   #9
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
chiptourqe can tune a chip to larger injectors.
Old 06-03-2007, 03:23 PM   #10
OED666
OED666's Avatar
Rollin went from an XR Fuel reg to a standard reg, and picked up 19 RWHP. He was changed while he was getting his car dynoed.
Too much fuel will lose you HP.
I would hold off putting in larger injectors until you actually have the turbo comfortably nestled next to the right front shock tower. screw you too for getting a turbo. :P
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 06:56 PM   #11
finnyman
thanks guys, well i might see if i can get chiptorque to get the right amount of fuel to air so it aint runnin too rich or lean...thanks everyone for your help, fourms are great lol ;)
