good morning all
Ive been recently looking into getting an HP4 cam and chip kit from Chiptorque http://www.chiptorque.com.au/Ford/EF4.html As you can see though the fitted price of the kit is $1750 for a gain of 15-20rwkw. I am just wondering if better gains can be had by choosing a different cam and having them make up a chip for it. I have asked them about the specs of the crow cam they use but im still waiting for a reply. It seems that people are getting gains of 20 rwkw without chips. Yes i understand chips are used for more than just power gains. so, Would i be better choosing a brand other than crow and getting a custom tune to suit? or is their package the ducks nuts that shouldnt be changed? cheers Tim |
i should also mention my Car is an EFII XR6 5sp. Mods are lukey extractors and 21/2 lukey catback. K&N pod.
#3 | ||||
![]() Join Date: Dec 2004
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
V8 Ute V8 Boat
put a cam in yourself its not hard
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
I intend to. What im trying to say is will i get better gains with their cam of choice or a different cam?
V8 Ute V8 Boat
get a second hand crow cam i had that cam in mine and it loved to rev but wasnt that lumpy, my new cams lumpy but i think it loved to rev better the that cam, i payed 200 for mine and did it myself
#7 | |||
Location: Under the bonnet, trying to keep as clean as above!
you will get better gains with a better cam. the question is is how big do you want to go? is it a daily driver, does the idle matter, do you do alot of H/W driving, what do the revs sit at at 100km/h, what are you future mods ect. shop around and ask plenty of questions. see what cam grinders recommend. don't just go out and by a cam that people say is good. pete j |
It is a daily driver, bugger all highway, from memory about 2.5g at 100km. Its an EF xr6 so it has 3.45 gears. Cam and chip are my planned future mods. I dont mind a lumpy idle
Nothing wrong with listening to the people, after all theyre the ones driving the cam'd up fords. guess ill do more reading cheers |
For those who might be interested, the profile they use in the HP4 package is a crow 2222549.
i used a 2222543 without a chip in my rebuild and only got 178rwhp. i'd be looking at a 2222546:
******* CROW CAMS SELECT PROGRAM ******* 16 COLBERT RD CAMPBELLFIELD 3061 phone (03) 9357 0469 fax (03) 9357 0001 WWW.Crowcams.com.au MODEL TYPE EA=EL 6 cyl OHC ---------------------------CROW COMPUTER CARD---------------------------- | PART NUMBER 2222546RH Date 7-SEP-06 | | Cam type: Hydraulic Roller type Profile | | ----------------------------------------------------------------------| | Advance Ground on Cam: 2 Lobe separation: 110 | | .050 VALVE TIMING | | Inlet opens: 8 BTDC Closes: 44 ABDC .050 Duration: 233 | | Exhaust Opens: 48 BBDC Closes: 4 ATDC .050 Duration: 233 | | ADVERTISED VALVE TIMING | | Inlet opens: 31 BTDC Closes: 67 ABDC ADV Duration: 278 | | Exhaust Opens: 70 BBDC Closes: 26 ATDC ADV Duration: 277 | | Inlet lobe lift at TDC on the over lap:.069 | | ----------------------------------------------------------------------| | Valve lift Inlet: .5280 Inlet Rocker Ratio: 2.00 | | Valve lift Exhaust: .5280 Exhaust Rocker Ratio: 2.00 | | | | ----------------------------------------------------------------------| | RECOMENDED VALVE TRAIN COMPONENTS | | Valve Springs: Spring height: Collets: | | Retainers: Pushrod: Lifters: | | H/D Timing Set: | | ----------------------------------------------------------------------| |
You win again, gravity!!!
I would seriously look at having your existing xr6 cam reground... only a couple of hundred for a regrind and shims... then you can go get a chip of some description. Certainly wont cost $1750 if you do the bulk of it yourself.
1994 ED Ghia SOON TO BE A TRACK CAR
#12 | ||
EB pete, ive been following your experiences with 2222543. Just about any search with the word crow brings up a topic of yours.
The 2222546 looks like a pretty big cam. What sort of power,1/4 times could you expect from this cam with a chip? Standard 5sp EF xr6 with exhaust/k&N. i assume standard fuel system will handle this? cheers Tim |
#13 | |||
yeah i get a good discount buying crow gear. i'd say with the 2222546, vernier cam gear, springs matched to the cam and a chip torque chip, you should be getting it down the 1/4 high 14's? what sorta extractors you got? pete j |
#14 | ||
Lukeys
