Old 08-05-2024, 07:42 PM   #1
goz007
Diesel Sniffer
goz007's Avatar
Default Re: 2009 MB Diesel just stalled and won’t start
As suggested by citroenbender, I believe the week link is the rocker arm & if the timing belt has lost its teeth, then I believe your engine will have broken rocker arms(unless it's merely lost 2 tooth& timing is only slightly out & the slight smack the valve has coped has not broken anything-i believe almost impossible.....butstranger things have happened)the other option would be to put a lower km 2nd hand engine in, u would probably find an engine for your model with much lower kms for about $600 + probably about $500 to fit.
goz007 is offline   Reply With Quote Multi-Quote with this Post
