09-12-2005, 09:20 PM | #1 | ||
Yeah I know, I'm crazy for wanting to keep it. But I like the fact when I put my toolbox in the boot the car actually sits right.
Anyway, if I were to put superlows in, is there any way to set the SLS up so it'll sit right? Or will the shocks just get flogged out anyway? |
09-12-2005, 09:23 PM | #2 | ||
windsor user
would there be any way to get some soft lowered springs
as far as i am aware, the system needs soft as springs to work., i investigated mucking around with the sls, was too much effort lol. was going to install a trim-pot to set the height etc |
10-12-2005, 10:53 AM | #3 | ||
I think it would work. Try it in the rears first see what happens. You'll need to adjust the height sensor to stop it belting air into the shockers. Theres sewwt f all adjustment in the height sensor you might have to crack out cable ties
10-12-2005, 10:56 AM | #4 | ||
Last warning
rob's not scared to rip out cable at the best of times ;)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
10-12-2005, 11:32 AM | #5 | ||
lol I was planning to keep the NC legit! I even felt bad hacking up the globe holders for the sidies so I could pop the AU ones one.
10-12-2005, 11:33 PM | #6 | ||
Two > One
cut the shock mounts inside the car and raise them say 40mm (or the ammount that the springs drop the height). Then you can run stock SLS shocks with SL's and retain the SLS.
10-12-2005, 11:35 PM | #7 | ||
Low and Loud
Dellboy knows how to, he has superlow height at the rear and its still stocko springs shockers or somthin.....
EDIT: EA2BA or whatever he calls himself now
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
14-12-2005, 11:52 AM | #8 | ||
PM me if you want
I cut down the length of the little bar that sets the height of the rear shocks, they are still in good condition the SLS still works 100%, very happy with it, I have LOWS in the front and the reart set to match.
14-12-2005, 01:42 PM | #9 | ||
Irregular Member
EA2BA, are you talking about the arm that links to the ECU? I know these had a very tight tolerance requirement to get the vehicle's height right, so a small change here would probably get you to where you want..
15-12-2005, 01:50 AM | #10 | ||
ill have a beer milkshake
one of the older guys i once worked with lowered his sls falcon and used modified replacement shocks and adjusted the linkages to suit, lowered the rear about 35mm, and he also had the shocks valved slightly different so you didnt get that sea sick feeling in the back!
current cars: 2001 AU SII XR6 manual 2001 Nissan Patrol 1969 Isuzu Florian 1976 Chev luv (really its just a rebadged Isuzu!) 1980 Isuzu KB 4x4 |
15-12-2005, 09:25 AM | #11 | |||
PM me if you want
