17-03-2005, 08:02 PM | #1 | |||
own the road
Recently while driving sometimes my car's steering seems to sometimes favour the right while driving. also my car seems to jump about on the road a little, both of these things usually occur over 60 km/h. Any ideas?
T3 TE50 #146 Quote:
17-03-2005, 08:07 PM | #2 | |||
AFF's 1st DM.......
Are your shocks leaking oil???
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
17-03-2005, 08:10 PM | #3 | |||
own the road
No, not as far as i know, and how do i find that out?
T3 TE50 #146 Quote:
17-03-2005, 08:15 PM | #4 | |||
AFF's 1st DM.......
push around on the cars body , if its springy the shocks are u/s, also have a look for oil weepage from the shocky rod.
17-03-2005, 08:18 PM | #5 | ||
they call me Tibbo
could be a worn tie rod end, or a worn lower steering shaft
When still and with the car not running, how much play is there left to right in the steering wheel before it actually starts to turn the wheels?
17-03-2005, 08:23 PM | #6 | |||
own the road
Racecreaft, i just checked it out and it's very stiff, not much movement goin on.
svo 347- it's a bit springy when you push it around.
T3 TE50 #146 Quote:
17-03-2005, 08:27 PM | #7 | ||
they call me Tibbo
ok so chances are its not a steering problem but a geometery issue, Like svo 347 said look into shockies or even something as simple as rotating your tyres..
How low is it? My EL with superlows and 17" jumped everywhere until I fitted the castor/camber kit
17-03-2005, 08:30 PM | #8 | |||
own the road
It's pretty low, a can just touches the muffler, and it sits a bit lower at the front. i had a cambor castor kit fitted about 2 months ago but that was put on when i had my old 15's on the car.
T3 TE50 #146 Quote:
17-03-2005, 10:05 PM | #9 | ||
Maybe just a wheel alignment is needed?
17-03-2005, 11:19 PM | #10 | |||
own the road
Yeh i thought maybe that too, but i thought i'd pose the question and hopefully i could get some useful advice.
T3 TE50 #146 Quote:
17-03-2005, 11:43 PM | #11 | ||
RIP...
Sounds like an alignment is needed, very likely have too much negative camber.
Rick.
. Oval Everywhere... |
17-03-2005, 11:45 PM | #12 | ||
Low and Loud
My EA does what your describing but its due to the Tierod ends being worn.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
17-03-2005, 11:49 PM | #13 | |||
own the road
When they installed the kit they put negative cambor on.
T3 TE50 #146 Quote:
18-03-2005, 12:16 AM | #14 | |||
RIP...
Give it more caster instead. My XH had zero camber, and 8 degrees positive castor. Rick.
18-03-2005, 12:21 AM | #15 | ||
01 Falcon Ute
have you got your car checked out since you got your rims and suspention fitted. Maybe a wheel alinement or your camber is out.?
AUII FALCON UTE 2001 WTD mags to suit AU Falcon ute, AU XR rims or BA 18" xr rims. PM ME |
18-03-2005, 12:42 AM | #16 | ||
I think it's the 17's bro. When I had them on my car they were tramlining all over the shop, especially when I hit bumps or braked.
An alignment should fix the problem, otherwise get the tyres replaced. Sundeep |
18-03-2005, 05:22 PM | #17 | |||
own the road
I think i'll get it checked out after easter, don't have the time or money before then.
T3 TE50 #146 Quote:
