FirstOnRaceDay
Hey I want to know how much work would be involved in putting in a Full EF/L interior into my EA...The hardest part will be the cluster and air conditioner part..
Was there a model that came with out a RPM gauge and just speedo, fuel, and temp... and would my standard air control unit fit in place of the EF one.. I wanted to do for a while now... |
DFDFDF
Mate,
Just buy an EF/EL.. hell of lot easier.. Not much of the EA-ED stuff goes across.. Door panels and seats are easy.. just not the dash.. Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
Last warning
easiest way is to change everything.
all the looms i'd say hardest part to do "properly" is the front seats.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
FirstOnRaceDay
Ok...
What if I did a combo... Did they make EF/L door trims in that charcole dark gray like in my EA? Cause I could use EF/L door trims with monty crome handles and a Fairmont EF/L leather rear seats and buckets up front.(like momo or something...) and could I use a EF/L middle console with an EA dash or not... |
Last warning
EF/EL console won't match up with an EA dash.
You could most likely use an AU console though. No dark coloured door trims, don't know how well they'd match.
DFDFDF
Maybe.. Lol.. Wats so wrong with the EA-ED interior?
Cheers, Nik
FirstOnRaceDay
not much^^
I might do a ED full interior like XR6 or 8... But I just have to find it... Wouldn't mind monty ghia interior either... |
#8 | |||
Does Steve have a car?
i remember somebody said once, calculate how long you think it'll take to do and then multiply by three ;)
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Its something I wouldn't do again. I don't regret it but my enthusiasim for doing that sort of stuff has dropped.
#10 | |||
EBII XR6
cheers
DEVLXR
#11 | |||
FirstOnRaceDay
Cheers rymers If I do it I'll drop you a pm. |
#12 | ||
there once was a
to mount the EF EL front seats you will need to cut the section of floor pan out of the EF EL and wel it into place of the EA ED floor , that way you can have the EF EL hand brake lever , also good idea for when you do the dash swap aswell .
Im about to do this convo to my wifes EA wagon , so basiclly ill end up with EA Body with Complete EL running gear and dash - centre console ![]() |
#13 | |||
![]() As you can see in the pic, the white section of the floor pan was cut from an EF and welded into place on the EA floor pan. It's basically just a bracket that's been spotwelded to the EF floor, so best way to remove it is to cut the whole section of floorpan out of a wrecked EF, then drill out all the spotwelds on a bench drill. There are ALOT of welds so be patient and make sure to drill the welds out evenly, otherwise it'll be a ****** to take off. Once this is done, you need to grind the existing brackets out of your floorpan and weld this bracket into position. Bit of stuffing around, but it will ensure a proper fit of your seats, centre console and handbrake lever.
