09-12-2014, 11:06 AM | #1 | ||
Had an interesting one the other day. was on my home from work when the Deflation Warning appeared. As I had just pulled into a town on the way home, I diverted to the nearest servo and checked the tyre pressures.
Found the front right to be a few psi lower than what I run them at, but I thought the Deflation Warning was not sensitive enough to pick up variations of only a few psi. Put some air in the tyre, rest the Deflation Warning system at the new pressures and have not had a problem since. Figured it must have been a instrument error. Anyone else experienced this? Craig H
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
09-12-2014, 11:25 AM | #2 | ||
Barra Turbo > V8
Mine has done the same.
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
09-12-2014, 12:22 PM | #3 | ||
Thanks.
Has/does it do it often? And does it still do it? I'm guessing that you haven't identified a cause yet?
09-12-2014, 12:46 PM | #4 | ||
75th anniversary
Mine has done it twice and both times only one tyre has been down a few psi.
The first time it happened i thought something was wrong with it because i was under the impression that it meant that the tyre was dead flat. I got out and checked it and no tyre was obiviously flat
LZ 2016 Focus RS in shadow black |
09-12-2014, 05:54 PM | #5 | ||
Barra Turbo > V8
Only does it when the tyre has dropped a cpl psi. Always the same though, it has never been more than about 4 psi when it has gone off
09-12-2014, 11:25 PM | #6 | ||
Mines done it a few times. From meomory if the psi drop below 4psi lower than the set psi the alarm will go off
Daily: UA11 BiTurbo Everest Weekend Project 1999 AU XR8 Past rides: Mondeo XR5 Turbo RIP: FGX XR8 MANUAL Build Thread: http://fordforums.com.au/showthread.php?t=11447239 AU Fairlane Sparkling Burgundy thread: http://fordforums.com.au/showthread....61#post5854961 UX explorer limited FOCUS ST, UT Explorer limited Written OFF BA XR8 Build Thread: http://fordforums.com.au/showthread....1299363&page=7 AU XR6 VCT ED GLI Classic |
10-12-2014, 07:41 AM | #7 | ||
10-12-2014, 02:55 PM | #8 | ||
Thanks guys!
Not sure where I picked it up (handbook, maybe?), but I was certainly under the impression that the Deflation Warning system did not activate with pressure variations of relatively small pressure deviations. With my experience and your individual experiences as well, it would appear that my understanding was indeed incorrect. Thanks again for the input. Craig H
13-12-2014, 12:37 AM | #9 | ||
I want to know how it sensors that there is a deflated tyre, as there's no pressure sensors in the wheels
GH Sigma EFI 351, 394whp @6500rpm |
13-12-2014, 11:03 PM | #10 | |||
14-12-2014, 01:12 PM | #11 | ||
Ah yep I thought it must have been something along those lines
14-12-2014, 01:44 PM | #12 | ||
Are there definitely no TPMS sensors in your wheels?
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan |
16-12-2014, 05:24 PM | #13 | ||
Nope
when I had new wheels fitted I used the original tyres and I was surprised that there were no sensors in them
20-12-2014, 11:03 AM | #14 | ||
Warning has come on for me about three times, pressure has been fine. Just reset and its fine again.
2018 Ford Focus RS |
23-03-2015, 12:44 PM | #15 | ||
Had this happen on the way to work this morning, got to work and found the front right tyre flat. Now I have to decide whether I change it myself or get RACV to come out to work and change it for me.
2016.5 TFII Kuga Trend. No modifcations......Yet |
23-03-2015, 03:24 PM | #16 | ||
_Oo===oO_
02-04-2015, 12:29 AM | #17 | ||
once your tyre is flat , the damage is probably done, big chance your tyre will end up knackered if you drove on it any distance,
also if you ignore the tyre pressure warnings and drive on it spongey or with very low inflation pressure its possible to do damage to the rim and then theres always a possibility if you happen to be going around a bend and the tyre has low pressure in it, it can become unseated from the rim and you could end up on your roof .......... ask me how i know this . |
22-05-2015, 01:55 PM | #18 | ||
Had ours go off last week, and upon checking the pressures, one was down to 25psi.
Was curious to see if I had reset it properly, page 11 of this PDF seems to explain it accurately - it's definitely based off rolling circumference calculated by the ABS sensor: http://www.fordservicecontent.com/pu...N13FOCqg1e.pdf Although I reset it while driving, so should remember to reset it tonight. |
