10-10-2006, 09:11 AM | #1 | ||
I Have Small Green Coolant Leak What Seems To Be Coming From Back Of Motor Approximately Where The Firewall Is,it Is Not From The Air Con Overflow Pipe,it Seems To Drop Onto Floor Below Where The Front Of The Centre Consol Is,any Help Appreciated
10-10-2006, 11:22 AM | #2 | ||
Tuned @ Pitlane Frankston
Could be:
Headgasket, heater tap, water gallery, heater hoses, etc. Take it to a mechanic and get him to pressure test it on a hoist. That's the only way to know for sure.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
10-10-2006, 11:55 AM | #3 | ||
yeh the pressure test will find exactly were the leak is, then its just a matter of fixing the problem.
10-10-2006, 03:32 PM | #4 | ||
Have A Swell Day
Yeah i've got the same problem atm on an EL near the water pump, just bought a new one + radiator.
10-10-2006, 03:37 PM | #5 | ||
/\/\etaL and V8s -Awesome
If its inside the car, its probably a heater box that has cracked open. Are you noticing if you front windscreen is fogging up a bit?
If its from outside under the car, have a look at the rear welsh plug, nasty! Cheers ViGiLaNtE351
Nothing Sounds Better Than A V8 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BA XR8 MKII EB Falcon ThermoFan Conversion http://www.fordforums.com.au/showthr...t=vigilante000 BA Falcon ICC Speaker Wiring http://www.fordforums.com.au/showthread.php?t=11342785 BA Wiper Motor in XE http://www.fordforums.com.au/showthr...=1#post5393955 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
11-10-2006, 12:26 PM | #6 | ||
THANKS FOR HELP GUYS BUT I THINK I HAVE FOUND LEAK,IT APPEARS BELOW SPARK PLUG ON LAST CYLINDER NEAR FIREWALL WHERE HEAD MEETS BLOCK AND TRICLES DOWN FROM THERE,SOMEONE SAID IT MIGHT BE HEAD OR COULD BE FROM INTAKE MANIFOLD,IT IS VERY MINOR LEAK ON TO GROUND SO IS IT WORTH WORRYING ABOUT AND IF IT IS HEAD WOULD I GET SOME TIME OUT OF IT BEFORE NEEDING REPAIR,CAR HAS DONE 127000 K's
11-10-2006, 12:37 PM | #7 | ||
I have the same problem on my ef, I got one welsh plu repaired wich cost around $50 - 80 but now i have a leak somewhere else aswell i will get it checked out today, hopefully its not a head gasket just a welsh plug :S
11-10-2006, 08:46 PM | #8 | ||
Heater hose.. hopefull not the head gasket!!
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
