Old 29-10-2006, 08:08 PM   #1
ScoopED
Thumbs up for fossil fuel
ScoopED's Avatar
Default EB V8, does it have a MAP sensor?
G'day,
Just wondering if the EB V8's have a map sensor? Or do they have a BAP?
Since I did the I6 - V8 conversion, I have been running the standard I6 MAP sensor with the V8. Should it be used in this way? Or does it have another purpose? i.e. Measuring atmospheric pressure (would be important in the USA with such great variations in the altitude that cars operate in.)
Mike
God created F-trucks so that you could put their engines into E series.
1992 EB Fairmont
351cu in Windsor Roller Cam
Valve Body "Shift Kitted" BTR 4spd Auto
Hi Tek Headers Tri Y
Twin 2.25 into Single 2.5in
17in x 8in BA XR8 Copies
235x45x17 Nankang NSII
Ultra Low King springs
Whiteline 30mm Swaybar
Nolathane box section trailing arms
Slotted DBA front rotors
Yella Terra roller rockers
ScoopED is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 08:10 PM   #2
Lumpen Proletariat
Originally Posted by ScoopED
G'day,
Mike
As far as I know all EFi Windsor's in Australia used MAF (Mass Air Flow). Most definately the E Series did. The V8's didn't have a MAP at all. The only V8's with a MAP sensor used in Aus was the LS1, and even then they also have a MAF!
Unsure as to how a MAP sensor would communicate with an ECU designed for a MAF?
Lumpy
Me: 1991 EBI XR8: Pearl Black. Manual. Full Exhaust. 16" CSA Edge. Trip Computer.
Dad: 1994 ED XR8 Sprint: Polynesian Green. Auto. Full Exhaust. Chiptorque Chip. 155.4rwkw.
Happy Dealings with: FordFan86 and Matt_971
Lumpen Proletariat is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 08:15 PM   #3
fairmont1998
fairmont1998's Avatar
Some early V8 Eseries did have a BAP sensor as well as the MAF. You should run the BAP with no vacuum line connected so it samples atmospheric pressure.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 08:47 PM   #4
MightyXR6Turbo
Boooostn'
MightyXR6Turbo's Avatar
Darin is right, they are EB1/NC1/DC1 V8's used BAP's, the BAP is the same thing as the MAP, if you follow Darin's instructions it will be fine. If your loom has a plug for it, go nuts and connect it up.
When I converted my ED to a V8, I used the wiring harness and motor from an NCII, so it was minus the MAP. I wanted to leave the MAP as a reminder of its I6 days, but someone *looks @ Darin* wouldn't let me! lol
2012 FPV GS Ute - Kinetic, Supercharged 5.0L, 6spd ZF auto, leather interior - The Boosted Daily!
1979 XD Fairmont Ghia - Silver, 302C V8, Full velour interior, slowly building her up to be a tough cruiser!
2002 Nissan Patrol ST - Desert Gold, 4.8L DOHC 6cyl petrol (Soon to be reequipped with a 5.7L LS1 V8), 5speed auto, lifted, locked, 33's, nature destruction vehicle!
MightyXR6Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 10:01 PM   #5
fairmont1998
Consider it weight saving Chris, no disconnected parts allowed :P
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 30-10-2006, 12:54 AM   #6
ScoopED
ScoopED's Avatar
Great, thanks a heap guys!!!
I started to suspect something while I was reading some pages online.
I was seeing 'BAP', and going "wait a second, thats an atmospheric pressure sensor, there aint no atmospheric pressure in my manifold!!!" (unfortunatly not even under WOT!!!)
Again, thanks for clearing it up. As of now, it is not connected to my plennum.
And surprise surprise, the engine also idles MUCH better now!!!
Poor bugger has probabarly been thinking that it has been opperating at 100,000 feet altitude for the past 6 months!!!!!!
Mike :
1992 EB Fairmont
