As above, where would I start to look for one, the engine that is? Or is there a similar later model variant?
Trev Last edited by Electra Blue; 29-05-2005 at 09:30 PM. |
Trev,
There's one on e-bay at the moment!
![]() as well as my 1971 Capri 3000GT! |
What sort of money are these cars going for? I'm interested in buying one as a project car (not specifically a V6).
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
www.capriclinic.com this guys sell new and second hand gear
Good luck trying to find a really good V6GT Capri that won't cost you a couple of limbs
I got a pretty decent V6 Capri for around 3 grand, and it was road registered. Look into getting a four cylinder one, cause many of them are able to kill a V6 Capri, unless of course, you like the lovely burble in the exhaust as you decellerate, then, you need a V6! The Essex is really good, considering it holds up damn well for a 72.
hey mate i got one, capri gt v6 3 litre, comes complet with the car,
contact 0404314075 |
#8 | |||
A.k.a wolf159
mate thoese 4s of your must off been 4 cyl pinto goes hard revs more an lightwieght kicks *** on v6
A.k.a wolf159
Ok.
The Pinto used in the Capri was a 2.0lt this engine with a single Weber 32/36 DFAV carburetor and 8.2:1 compression. It produced 64 kW (86 hp) and 140 N·m (103 ft·lbf). Even the 1.8 Dohc only produced 115 hp, admitedly they can produce good power when worked on. The Essex v6 used in the is good for 142hp in baseform and around 170ft lb of tourque, and when breathed on can produce 250+ hp and a lot more tourque. So the extra weight of the v6 is of no consequence, they also will pull fairly good revs, in fact only slightly less than the Pinto you love so much. And fyi in all the many years i've own'd V6 Capri's never have I been beaten by a Pinto engined vehicle either standard or worked over.... |
#11 | |||
I keep this brief.....The V6 is basically built for torque so where having torque is an advantage, ie hill-climb on the freeway etc blowing a 4cyl away is what the V6 does best. However, where a good worked 4cyl comes into its own is excelleration. I'm a big fan of both the 2lt Pinto and the Essex V6, I own an RS2000 and a GT V6 Capri. To compare the cars would be crawl but I'd have to say the Pinto would have the Capri off the line 10 times out of ten, but cruising at 100, then dumping the foot would see the pinto really struggle against all that torque (even with the big cam thats in my RS2000)
Theres an old saying - "there's no substitute for horses"....Which we all know is just pub talk. Having a std base torque of 260Nm at only 3000rpm the V6 makes it a pretty good start for a performance engine. Unfortunately, the cost and availaility of parts makes working up a Essex pretty much, uneconomical. .....Oh, to answer the original question - Try placing an ad in your local Capri Club newsletter. There's usually a club member got one stashed away somewhere. |
#13 | |||
buickman
Panels & interior are now starting to get scarce as well. So chose wisely unless your good with the torch & mig. Mechs are not a big issue |
#14 | ||
eskie freek
hey if ya still interested in 1 i have a four cylinder for sale pm if interested i want bout $850 for it
black mk1 on goin project/ toy 94 ef xr8 toyota 60 series project with 6inch lift and 35z ![]() Xd sedan project for sale mk1 4 door project car for sale Mk2 4door 1.6lt for sale |
#15 | ||
1.6L or 2L
1980 Coupe, Blue, 1.6L, 2" exhaust and extractors. Oversteer Scares The Passengers , Understeer Scares The Driver WWW.QLDSTREETSCENE.COM/ |
#16 | ||
eskie freek
1.6 and drivein
#17 | ||
How Much r u willing to pay for 1............does it have to be an original GT..............wat Year
#18 | ||
After a VERY tidy capri v6, GT would be a bonus. Will travel for right car. (Eastern suburbs of Melbourne)
#19 | ||
Give JR (John Roberts) from the Capri Club a call. 0409 091 252. I was speaking to him last night and he has one in good condition, just need putting back together.
#20 | |||
#21 | |||
I just wanted to check if this car is available or if it has been subsequently sold. I am also interested in finding a GTV6 Capri, or even an RS3100 if I was lucky enough. Jamie |
#22 | ||
I have the complete driveline for out of a gt, dismantled motor (complete) good gearbox, and the diff with tail shaft. make me an offer as i want to get rid of it all. i am in adelaide
#23 | ||
Do you still have the running gear Sean?
E-mail me at radioactiveman1@optusnet.com.au. I would also like to restate my search for a V6GT Capri, RS3100/2600 Capri or even a '69 1600GT Capri. Thanks Jamie |
