Old 11-11-2006, 11:03 PM   #1
falcon351
HANK
falcon351's Avatar
Default Shift kit
hi.
i was just wondering what yous think of those cheap shift kits. there are sum on ebay for 50 bux. has any one got one or been in a car with one as i would like to know if it is worth geting one. they claim to make an other wise stock falcon chirp into 2nd. do u rekon theyre dodge? here is a link to the same kit but for BA as i cant find an e series one again. http://cgi.ebay.com.au/Shift-Kit-to-...QQcmdZViewItem
thanks guys, any help would be appreciated.
1992 EBII Fairmont
Lowered 30mm on kings springs and monroe struts/shocks
Performance catback exhaust with stainless 3 in tip!
Shift kit!
Tinted windows n tail lights.
Pioneer 200w flip face head unit
600w pioneer sub backed by my nu 640W kenwood 4 way amp
Eclipse 6x9s and 6's
Clear front and side indicators
115 rwkw on regular, not bad for pod, catbak!
Back on the rd! nothing can stop us, not a defect or even a stoby pole!! BAHAHA NEVER SAY DIE!!!
falcon351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 11:04 PM   #2
falcon351
HANK
falcon351's Avatar
oh, that is not the one that claims to make falcons chirp into second but it is similar, and yes i do realise that it is the BA add.
1992 EBII Fairmont
Shift kit!
Old 11-11-2006, 11:07 PM   #3
falcon351
HANK
falcon351's Avatar
Here we are, sorry about all these posts but i just found the 50 buk, chirp inducing shift kit for E series falcons i was originally thinking of
http://cgi.ebay.com.au/FORD-FALCON-S...QQcmdZViewItem
1992 EBII Fairmont
Shift kit!
Old 11-11-2006, 11:28 PM   #4
itzdamafia
If you go for this you might as well buy the 20hp mod as well. I wouldnt try somthing like that on my car unless it has been tested by someone over a few thousand kays
Old 11-11-2006, 11:32 PM   #5
falcon351
HANK
falcon351's Avatar
thanks for the advice. i generally figured this as im a bit skeptical about these cheapas mods. hopefully sumone on here has got/had one and can offer advice.
thanks man.
1992 EBII Fairmont
Shift kit!
Old 11-11-2006, 11:41 PM   #6
EF302
buy one from shiftkits.com, and u can get one thats fully adjustible. and yes they do chirp second
EF302 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 11:48 PM   #7
falcon351
HANK
falcon351's Avatar
sweeeeeeeet
1992 EBII Fairmont
Shift kit!
Old 11-11-2006, 11:51 PM   #8
falcon351
HANK
falcon351's Avatar
hey i cant find it on that site, it seems to be all american stuff only.
1992 EBII Fairmont
Shift kit!
Old 11-11-2006, 11:52 PM   #9
falcon351
HANK
falcon351's Avatar
oh ic, u have to go .com.au
doh! ye they sell them on ebay, so u rekon theyre worth it aye?
1992 EBII Fairmont
Shift kit!
Old 11-11-2006, 11:59 PM   #10
itzdamafia
The shift kit website is here http://www.shiftkits.com.au/ShiftKitsFord.aspx
These are about as close as your gonna get to a shift kit without modifying the valve bodies.
The shift kits from here make the shifts firmer but be aware that its not something you leave on all the time as the firm shifts wont give a smooth ride. Use it for a quick splat or whatever. Your choice.
Old 12-11-2006, 10:21 AM   #11
rmack
rmack's Avatar
The eBay one's are probably the old resistor mod like this (for the EF).
20 Ohm and 1 Ohm for (EB-ED)
EL has the same resistors as the EF but different pin to the ECU (57,38)
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 10:56 AM   #12
Dezza
Parts bin special
Dezza's Avatar
My current auto chirps into second but that's because the S5 solenoid is stuffed.
I think Ghia5L has fitted a shift kit so he should be able to give you some advice on the matter.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 03:27 PM   #13
mcflux
mcflux's Avatar
Electronic shift kits probably aren't good for the auto's health, but I've got a mild one anyway. It's hobo-style, with no on/off or variable toggle. Before the stally it firmed up/quickened up the shifts as well as chirping 1st-2nd and making the backside wobble for 2nd-3rd, but since I've had the stally fitted it's removed the roughness but retained the quickness, if that makes sense.
My box is 350,000kms old and its only sign of wear that it had was a harsh 1-2 shift just after the car was started and driven (cold), but that was before the stally was fitted.
$10 should cover the parts you need. www.mechanicalforums.com has schematics. I've probably posted this a dozen times though, search helps ;)
Old 19-11-2006, 12:15 AM   #14
falcon351
HANK
falcon351's Avatar
Thanks. lmao, hobo-style
1992 EBII Fairmont
Shift kit!
Old 19-11-2006, 12:31 AM   #15
theboss290
FPV GT
theboss290's Avatar
Who wants to buy an EF two stage shiftkit from shiftkits.com comes with the installation instructions. The reason for selling is I didn’t know the resistors are different to an EB. I would like to swap the EF one for an EB if any one out there has one lying around.
pic
theboss290 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 01:56 AM   #16
Heffnic
this is true
Heffnic's Avatar
one of my mates wrote off his car with one of these bewear they can be dangerous especially in the wet.
EF Fairmont, stage 2 crow cam, 18" apache rims,xr air intake,full Lukey exhaust system, supalow springs, green dash mod,last dyno 145rwkw,stereo :gren:
Heffnic is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 08:27 AM   #17
nothin suss
nothin suss's Avatar
I done the simple resistor mod about 2 years ago to my trans (ED I6)... The car & auto had done about 200,000klm at that stage and has done about 40k more now and no dramas. Doesnt chirp but in a straight line. Sometimes under medium accel around a long corner? In the wet it will spin into second and 'wobble' a bit into third tho.
From memory there were a few different resistor options (mild, harsh) and i went the soft option.
PX3 Ranger - family truckster
BF Fairlong Ghia - boostlounge 11.26 @ 121
nothin suss is offline   Reply With Quote Multi-Quote with this Post
