XY
Hey,
I have a 302 windsor lying around and a TE cortina with a 4 cylinder, 5 spd manual. I am wanting to fit the 302, but can anybody tell me what needs to be done to get it to fit? Do they drop straight in? also what gearbox and diff do you guys recommend? Thanks Tom
IGOTTABIGBLACKSHINEYCAR |
XY
Can anybody help?
XY
surely someone must know something?
Just put a rocket in it.
Duct tape it to the roof.
TE cortina 14.0 @ 101mph E32 740iL Leather, sound system, rollin' on 19's |
#5 | |||
XY
Hmmmmm Mulberry....
I got a TE Corty with 302W C9 auto.
I run Castlemaine rod shop engine mounts and extractors. C9 Auto and a Borg warner Diff. Runs 13.6@101mph. It is a stockish engine. The original car was 6cyl auto. |
Hmmmmm Mulberry....
Send me an email at chrisnaughton@bigpond.com and I will send some pictures if you like
XY
sounds good chris, id love to see some pics, my email is tom351xy@hotmail.com
Ive got thousands of questions, but ill ask another time. Thanks for your reply
#9 | |||
would this be the one in perth?
with snowflakes?
Heavy right foot
adrian selemeyer also did a conversion kit
bronco type sump and pickup are needed you can even by headers already made to fit ![]() |
If its just going to be something for fun at the drags I would use an engine plate at the front instead of mounts. Be more solid and give you more room for extractors. If the engine doesnt have huge horsepower a decent C9/4/10 and a minispooled Borg Warner would be a good cheap setup
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo |
#12 | ||
Watch the 4cyl firewall,apparently they are different to the 6cyls and may give clearance issues with the V8.
Also, put the biggest brakes you can afford on the TE, extra insurance ![]() |
#13 | ||
The guru who started V8 Cortina conversions back in the early mid 80's (hmmm showing my age) was Bob Pinnell who was at Berowra back then. Used to supply kits and was very prominent around the drags at that time. Not much he didn't know about stuffing a Clevo or Windsor into a Cortina. Might be worth seeing if he is still around.
#14 | ||
XY
thanks for the responses, im not 100% that i will go along with this yet, just seeing how difficult it is, but thanks.. its making me want to do it now.
#15 | |||
The swap is so common that it shouldn't be too hard to get good info. Definitely look at the Castlemine Rod Shop, they have all the bits and pieces to do the swap including brakes. I would recommend them as I have used their bits for a Clevo into Capri with no hassles. Some though have had issues, but I wouldn't stress. If you go Windsor, the swap is very easy, go for it! ![]() |
#16 | |||
#17 | |||
The Pinnel kits were ok, though I had to use the CRS kit for WA registration as the authorities insisted I install the chassis kit. |
#18 | |||
