Old 02-04-2008, 03:30 AM   #1
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
Default More tyre questions..
Hi all..
I picked up some tyres on the weekend in preparation for my first outing to the track in May (AFF meet). I have a few questions about them, and running them on the car.
The car in question is my XB coupe (383/4500 stall/4.11's). Runs 295 BFGs on the street.
The tyres I picked up are 275/60/15 D.O.T. approved (treaded, sort of..) Hoosiers. They were on a Group N (i think) HQ circuit car. Used for one round or so, then replaced. I got them free, and can't justify buying a set of new tyres for what will possibly be the only trip to the track this year...
From what I've been told, if warmed up these are reasonably sticky tyres, and should do ok on the strip. Any comments, opinions on this? anyone else use/used these tyres for this or any other purpose?
the other concern I have is that as far as I know, these are cross-ply tyres. From what I have read these shouldn't be run with radials on the front, due to wandering issues etc. Is this just for cars that run over certain times? or is it a case of 'no matter how fast your car goes, you shall not run with mixed tyres'?
The 275's did come with a matching pair of 225 hoosiers, but are heavily cambered due to how they were previously used. I'm worried that running these on the coupe would be a bit risky due to the wear on the tyres not matching the alignment thats currently set on the car.
one last question - for now, these tyres have tread wear indicators on them, are they ok to use on the track all the way to zero tread?
all coments/opinions/advice welcome
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2008, 10:18 AM   #2
jcxr
Tribal Elder
jcxr's Avatar
Suggest you put cross plies up front. On the freeway they wander like all getout. At the drags, under accelaration though, its not so bad. What times do you anticipate??
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2008, 12:23 PM   #3
montyv8
montyv8's Avatar
no idea, I've never raced on the track before so my driving will more than likely hold the times back, but the car should be capable of very high 12's.
I'll probably run 15's now haha..
8.23@168MPH
Old 02-04-2008, 03:09 PM   #4
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
I have the same tyres in the shed Phil,
I found them good for cornering grip when new,but I could smoke them all the way through 3rd gear on the power in the old XA.
I was keeping them aside for powerskids,IMO you'll be dissapointed.
One other thing,even when I had these tyres front and rear,they would wobble down the road like a drunk chook until about the 3rd lap..
These are very different to a drag slick..
I may be able to lend you my slicks for a run or 2 depending on how things go..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 01:40 AM   #5
montyv8
montyv8's Avatar
these are the tyres in question:
are these the same as yours Tony? anyone else have any comments?
8.23@168MPH
Old 12-04-2008, 03:35 AM   #6
GASXR6
GASXR6's Avatar
andra RULE BOOK says
"cars quicker than 12.50 (1/2 mile) and 8.00 (1/8 mile) using independant front suspension and cross-ply rear slicks are not permitted to use radial front tyres".
LIKE NUGGET SAYS YOU WILL PROBABLY FIND THEY'RE GOOD FOR TURNING OFF AT THE END OF THE TRACK!!!
I know it's hard to justify for 1 meeting but if nugget is offering the loan of his slicks I would take the offer up.
Just remember you spend a lot of your hard earned dollars on engine and driveline and if you were to damage it because you just can't get traction It would be a waste.
I've never seen a golfer T off with a cricket bat and all drag race cars have SLICKS!!!!
383 Clevo, CHI 3V's, solid roller, Glide. 7.97@164.83 mph.
GASXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 09:28 AM   #7
nugget378
Weezland
nugget378's Avatar
Exact same ones Phil,they are still in my mates shed,also have tried the goodyear bluestreaks,which have a wider contact patch for the width I think.
I have a contact and can get these used quite easily,but have found them not worthwhile with the tyres available to me,these guys run them due to class rules,if they didnt have to they wouldnt.
Do they feel like they have a hard skin on them but softer underneath?
By all means try them,but leave yourself a backup plan is my advice..
Old 13-04-2008, 09:33 AM   #8
xagsjoe
Patience is a virtue
xagsjoe's Avatar
High 12s eh phil? Dont think you will have too much trouble knocking a second off that if you take up Tony's offer. You still runnin the same converter? Did the gear change help??
xagsjoe is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2008, 02:50 PM   #9
GASXR6
GASXR6's Avatar
That would be 12.50 1/4 mile not 1/2 mile btw.
Old 14-04-2008, 12:59 AM   #10
montyv8
montyv8's Avatar
I thought it better to go with that than say "oh it'll run 11's for sure" and then go slow as
Yeah same converter. I only dropped the diff center off on thursday lol... should have it back mid this week
The problem with taking up Tony's very generous offer, is he'll be racing on them most of the weekend..
8.23@168MPH
Old 15-04-2008, 07:26 PM   #11
Walkinshaw
Two > One
Walkinshaw's Avatar
Pffft, Tony's is a Wheezer, the slicks will bog it down. You'd give it a much better home behind a Clevo
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2008, 08:34 PM   #12
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Don't break anything on Friday dude, i want to take some pics on Saturday, and i'd prefer they are not of another hole in the floor. :
Falcon Coupe is online now   Reply With Quote Multi-Quote with this Post
Old 16-04-2008, 02:23 PM   #13
montyv8
montyv8's Avatar
problem pretty much solvered, thanks to Bish a pair of Mickey-T ET Radials are heading my way
8.23@168MPH
Old 16-04-2008, 06:18 PM   #14
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Mmmmm... rubber....
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2008, 08:58 PM   #15
ebxr8240
Performance moderator
ebxr8240's Avatar
Yep here's an example of what can happen...
Joe Dirt racing ?? Lol..
http://www.fordforums.com.au/showthr...=1#post2092468
Daily driver GTE FG..
