Old 04-07-2005, 10:12 PM   #1
shortyrules
Default air intake on 1600
got a question bout air intakes and carbys. do u want hot air going in or cold air. i know with efi u want cold air but i think with carbs u want hot air.
any suggestions on good air intake setups?
eskys standard 1600 with the motocraft carby. didnt have the original air cleaner and the piece of crap that was on it is letting in way 2 much air and im getting back fires
need sum suggestions 4 a replacement and also jetting.
got the stock 137 main at the mo and wanna know wot to go up 2
any help would b good
thanx
shortyrules is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2005, 01:37 AM   #2
rota-eski
u want cold air going in, no matter what the engine, the colder the air the more dense it is. n the denser it is means u can cram more of it in the cylinders... thus intercooling with turbo cars.....
a good set up would be a bit like the old toyota hi-ace set up... they had the carb then had tubing running off it into a pod-like filter in the side panel.. this means it can suck fresh cold air in, instead of hot old air from in the engine bay.
as for the carby, dont bother with the original 1, spend the $$ n get, at least one 40mm weber... two 45mm's would no doubt kick *** but they will cost u a fair penny... go with the single i guarantee u will notice a decent gain
by the way ur lookin at about $250 for the single carb with the manifold, but u can get em as cheap as about $150 if u shop around
Old 05-07-2005, 06:14 PM   #3
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
I agree with what rota-eski said, you want the coolest air possible going in, and the standard motorcraft carby is rubbish, if you can replace it with a webber you'll be much happier with it.
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
