Hi Guys,
I've spent a bit of time behind the wheel of my ST170 now and also have been browsing through the owner's handbook and have begun pondering. As you all know, the ST170 comes with two oil gauges set in the left hand end of the dash, which I personally regard as a bit ****y and a waste of valuable dashboard real estate (ducks for cover...) Now some of you may want to burn me at the stake for suggesting this, but I think I'd like to rip those gauges out and replace them with something more useful, like a trip computer / outside temperature display unit. I believe the LR Focus Ghia does have a trip computer fitted in that same location on the dash, so my questions are: - Does the ST170 have all the sensors & wiring in place to support the trip computer unit? - Would the LR Ghia's trip computer be a direct swap for the oil gauge unit on the ST170? - How much of the dash would I have to pull apart? - Any ideas where I'd be able to pick up an LR Ghia trip computer? Cheers, Brian |
Motorsport Guru
Brian, I can answer Q4 for you as a Trip Computer for my LR is on the Christmas wishlist. I believe the Part No. is 2M5T10(that's a zero)D885EB and it's description is as a Display Indicator. I was quoted around $360 from the Dealer which I purchased my Focus from and I believe that's a supply-only quote and that price was back in June this year. It'll certainly be a worthy enhancement for my Focus and it'll fill in that blank space they call a Coin Tray.
Hope this helps and that you're enjoying your ST170. Lucky fella. Eddie.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System. Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle. Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust. Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus. |
#3 | |||
Brian |
AFF Post NAZI
Ive got the Gia Trip computer installed in my Focus Zetec. - GOD SEND. love it.
but if you buy a ScanguageII it will do alot of that as well. just not as neatly as the Ghia input.
AFF Post NAZI
dup post
#6 | |||
I believe you need both the computer unit for the dash and an upgraded LHS control stalk to operate it? Did you need to install any additional sensors and wiring or was it just plug and play? Did you need an ECU reflash to make it work? Cheers, Brian |
